- Sep 5, 2024
- 1993
Nice rear mudguard, and without the passenger foot pegs there's a better view of it. 👍
Great catch, didn’t even notice that from R @Rijack pics. I’d think they wouldn’t get very warm since they usually don’t run as many heating coils around the underside of the grip. At least not as efficient as if they were more correctly positioned.I never seen the heated grips installed upside down, is there some reason for that?
Came like itI never seen the heated grips installed upside down, is there some reason for that?
It look tidier and are made of harder rubber so it should last a lot longer than the soft oxfords. The hottest setting is too hot for longer rides for me so after initial warming i always set it to the lowest one.Can highly recommend the genuine ones, the throttle is harder to install then generic heated but I think the work better. Have noticed Oxford are now supplying with the switches built into the left grip so looks a lot tidier.
Try to use a syringe filled with isopropanol, stick a needle under the grip and try to dissolve the glue. I read somewhere that it work with Honda grip glue so maybe it will help here.They are VERY glued on from a previous keeper. Might need to slice them off for replacement. But will try putting them on 100% heat and twisting to see if they loosen at all…
Thanks I’ll look into thatTry to use a syringe filled with isopropanol, stick a needle under the grip and try to dissolve the glue. I read somewhere that it work with Honda grip glue so maybe it will help here.
I could say after first spring rides, for now there are heavy coat of snow everywhere.@Mr.D Other than since you have an aftermarket exhaust, I am curious how is drivability difference with the PAIR plates?
