- Feb 18, 2021
- 2019
AFAIK, default (3rd) is 70kg and the lowest (1st) is 50kg.I’m going to make this clear because it’s not very helpful when people mention a specific weight and a specific setting for the rear shock. Honda should provide a table, so I’ll create one right now. Feel free to correct me if you think any of this is incorrect.
Let’s assume the minimum design load for this bike is 60kg. Therefore, preload setting 1 would be ideal for a rider weighing 60kg in their riding gear. The maximum load-carrying capacity (rider, passenger, luggage, and accessories) is 154kg. So, we’ll assume that this is ideal for preload setting 10. Using these limits, let’s do some simple math.
154-60=94kg weight range.
94/9=10.444kg per “click” of preload (there are 10 positions, but only 9 “steps/clicks” between positions).
Preload 1: 60kg
Preload 2: 70kg
Preload 3: 81kg
Preload 4: 91kg
Preload 5: 102kg
Preload 6: 112kg
Preload 7: 123kg
Preload 8: 133kg
Preload 9: 144kg
Preload 10: 154kg
Choose the closest setting to your load. If you’re between settings, go down for comfort or up for performance/stiffness. Try both and see which works better for you.
For my American friends, you can convert using this conversion ratio: 1kg = 2.20462lb.
Do you agree that the lightest design weight is 60kg, or should I adjust it? The upper weight limit is already set by Honda, so I think that’s correct. All of this is a guess since manufacturers don’t provide clear information on setting preload.
