Hi, I had similar issues, not as pronounced as yours. I weigh 158 pounds when I first had the bike at 1200 miles it would struggle for grip over shallow bumps on throttle. Very harsh ride, rear spring preload backed off. Swopped rear spring for one inch lower progressive rate and it was 75% better. I have covered 5,000 miles with this spring but I am still not happy with the constant jarring through my back. I have spoken to a shock specialist and he said a new specific shock for my weight will give me at least 50 to 75% better ride quality. The new shock will be lowered one inch with a lighter spring adjustable bump and rebound. £375 Inc vat. For me it is either a shock or a bike change I cannot carry on as it is at the moment. I tried adjusting rear spring pre load and tyre pressures to no avail. After all the rear shock is a budget compromise unit. This is just my personal experience. My bike doesn't like bumps full stop, but it handles well and I have a sensitive back. I hope this helps. Good luck.I’m finding the rear shock only works below about 60 mph. After that speed the ride becomes harsh and some bumps in the road cause the rear of my bike to kick up. It’s not a mild feeling of kick up. It is an alarming feels like the bike is out of control situation. It happens at least once almost every time I ride my bike.
I have 20k miles on the odometer and I can’t decide if the rear shock is just worn out or if it is a bad design.
Without knowing the cause it is hard to decide what to do.
I weigh about 200lb and the preload is set about in the middle of the range.
US currency shows that YSS at $531, an Ohlins can be had around $550-$600 and you have something anyone can work on and gets parts for.This may be a cheaper way to go if required.It can't be all bad as it is made in thailand?
https://www.asian-motoparts.com/en/...-shock-absorber-yss-mz506-honda-cbr-650f.html
That's the stiff version isn t it ?Haven't had confirmation on the tyre type in use? GT variety of Pr4 could easily explain this.
Post #22, yup.That's the stiff version isn t it ?
Post #22, yup.
Looking back at your intro post, you have a long motorcycle history and your previous bike was a Versys, but let me ask if you’ve had a sport-styled cycle before? Because kicking back in sharp edged bumps is very normal for stiff OEM suspension on a short wheelbase bike and would be something not noticed in a car or softer suspended motorcycle. I ask because sometimes people have expectations that aren’t going to be true no matter what; this is designed to be a “sporting” riding motorcycle and will always have a sense of instability.The tires are plain pilot road 4s, not the GTs.
I found the section of road and duplicated the rear suspension kicking feeling. It’s an overpass that has a sharp edge in the transition to flat at the top of the incline. The fork does ok but the rear suspension seems to non compliant and its a nasty jolt.
I drive my car over the same road often and would never have guessed this little bump would be such a problem for the CBR650F. There are worse bumps on all my favorite roads.
Thanks for the info.I owned a 2005 GSXR-750 K5 and a 2006 cbr600rr. I used them as primary transportation. I didn’t own a car back in those days.
The Cbr650f suspension is softer but seems to do fine up to 60 mph. After that, it does not seem to do as good a job of managing bumps.
I agree that the kickup problem could be the result of too much compression damping. But the shock is fine for low speed compression damping. It is high speed compression damping that seems excessive.
The gsxr750 and Cbr600rr both have cartridge dampers. It makes complete sense to me that having experience with two of the best sport bikes of their era would leave me dissappionted in the Cbr650f suspension which does not have cartridge dampers.
At this point I am thinking the Ohlins shock and cartridge damper setup is most likely to meet my expectations. It’s a lot of money so I’d like to hear from anyone who has done this upgrade so I can confirm it’s the right move.
There’s nothing else wrong with my Cbr650f. I see it as an upgrade away from being my ideal bike. I know I am asking more of it than it can do in stock form.
The gsxr750 was terrifying at full throttle. I admit it was too much bike for me. I tried going 150 once and will never try that again! The Cbr600rr and the gsxr750 both have riding positions that are not comfortable for me anymore and that’s why I picked the Cbr650f.
I dream of a Cbr650f with the Cbr600rr’s fantastic suspension!
Very interesting, I would like you're input and experience after the rear shock mod. I would especially like to hear how it performs over bumps and pot holes . I have to upgrade the rear shock or have a bike change which i do not want to do. It would be nice to hear how the bump and rebound make a difference from full stiff to fully backed off. I wait in anticipation.Going to order the Ohlins shock and install that first. I’ll post again once it is installed and I’ve had a chance to ride it.
If I end up deciding to do the fork that will probably have to wait until February for budget reasons.
Do you know what spring rate you are getting.?I ordered the Ohlins stx46 shock yesterday from RevZilla for $600.
It will probably be 2 weeks before I receive it and have it installed on the bike.
