- Feb 17, 2020
Would you recommend replacing the gaskets for the install Even if there’s only 150 miles on the bike?
 @Brammers kindly told me so) so get yourself some.
		@Brammers kindly told me so) so get yourself some.I am iffy on that if you have already installed it and there is no leak ( my case but I changed it anyways and it was hell of a bad experience ) but if you have not installed it yet, yes definitely change them. its like 4 bucks each, so pretty worth it. Make sure you put a little bit of oil on them before installing. They dont stick.Would you recommend replacing the gaskets for the install Even if there’s only 150 miles on the bike?
Is it that easy to just put the baffle back in? I’ve read a lot of shit with people saying how hard of a time it was to remove it. Thanks for the guidance though.it will not cause any problems man. Just take it our for a better sound and put it back whenever you wanna go for longer trips. You will lose some back pressure but it will be trivial.
 @EnglishBikerDan  has posted
		@EnglishBikerDan  has postedThe more you do it, the easier it gets. But you can also ride the bike in a manner that doesn’t need it in if you choose. Run a gear or two higher than you normally do and keep the rpms low and it will be quiet.Is it that easy to just put the baffle back in? I’ve read a lot of shit with people saying how hard of a time it was to remove it. Thanks for the guidance though.
Look on the akra website at the euro4 ECE compliant exhaust. The CAT is ordered separately.T
the cat that’s built into the akrapovic? Sorry still new to modding bikes
The manifold gaskets are not mileage dependent, they are single use, crush gaskets that won’t “wear out” but instead form a seal to your exhaust ports and header pipes. I question whether your dealer or mechanic understood the actual gaskets you were asking about and were thinking more along the lines of a typical exhaust where there is a gasket between the muffler and headers. THOSE would reusable, and they would have a life mileage dependent.Just a quick feedback regarding exhaust gaskets. I didn't remember changing them on my previous bike (CBR500R) and that's because I kept the original ones. I changed the downpipes twice (Arrow and then Yoshimura), rode the bike +70k km and never had any issue. I did the same on my CBR650R: changed the exhaust system after 500km, no issues so far. I double checked with my dealer and another mechanic, they both said that at such low mileage there is no real need to change them. I'm not saying you cannot have issue, nor that's the path o follow, but that's just my two cents.
 @fogducker that show how well the second removal and install went.......
		@fogducker that show how well the second removal and install went.......You are fine running an Akra without a baffle and without a cat and without a tuner.When people are saying they ran a full system with no tune, do you mean full Akra without baffle and CAT without a tune?
Or a full Akra with both CAT and baffle?
The latter would run se as stock, the former would be super lean wouldn't it?
I'm thinking of running the CAT and no baffle. Hoping the CAT retains enough back pressure to maintain n the AFR, and no baffle for sexy sounds...
Is this something you have done for a while?You are fine running an Akra without a baffle and without a cat and without a tuner.
It's something a lot of people have done for many miles. I ran mine with the baffle in for 5,000 miles before I sold it, the next owner pulled the baffle and put another 8,000 on it then traded it in on a GSXR, zero issues.Is this something you have done for a while?
I was at the show too!Saw this yesterday parked in front of the Toronto mot show
Seems pretty slick to me. Although I’m not a big fan of side mounted pipes.
Nah real! I paint as a side job. cant come out that neat! Let meet up next seasonI was at the show too!
Also pretty sure those colours are self-wrapped/painted?
Would love to meet up too!Nah real! I paint as a side job. cant come out that neat! Let meet up next season
I just spoke to a revzilla tech over the phone and he strongly advised against drilling out the tac-welded baffle. I’m about to order my Akropovich system but I don’t want to drill the baffle out without getting tuned if it’s going to cause problems. Any advice?
I’ve been riding with the baffle out for a couple weeks now and it sounds incredible but my hearings gonna be completely demolished if I don’t get some quality ear plugs soon lolThat's just standard corporate-speak. If you called Apple and asked them about jailbreaking an iPhone they'd say the same thing (sorry, lack of better analogy!).
This exhaust sounds absolutely amazing with the baffle out (and really, not that great with it in). Still no tune required. And the sound isn't annoying when cruising. It's just...awesome.
100% agree. I purchased a set of Eargasm (https://eargasmearplugs.com/products/eargasm-high-fidelity-earplugs?variant=12120483004489) earplugs and love em. Can still hear my music and other folks I'm riding with perfectly fine and it brings the exhaust note down just a touch.I’ve been riding with the baffle out for a couple weeks now and it sounds incredible but my hearings gonna be completely demolished if I don’t get some quality ear plugs soon lol
