- Sep 2, 2019
My shifter finally arrived yesterday here in Finland.
Installed it by myself and now I'm going to install heated grips aswell so can't go ride just yet.
Send us some pics if you’re done with the heated grips?
Do you still have those QS in stock?www.shifter-france.com
I'd try to poach you, but I have to be honest about the shipping times right now - you don't want to wait for a package from Canada ...
How does one go about getting one? What company makes it? Same install process as OEM?Yes - one left!
Did you get yours from the Honda dealer as an OEM part? I am also in Finland.My shifter finally arrived yesterday here in Finland.
No problem.I ended up ordering Honda quick shifter from Amazon Japan at the same price. Thank you anyway.
Both are simple switches, they don't do anything themself, they just tell the ecu the shifter got triggered and the ecu does the actual cutting fuel/spark or whateverSorry for being digging this post! But would you prefer Contiroll over OEM? Because I have OEM but the shifter feels a little harsh. (I've set it at 279mm instead of 269mm) because I dont like the shift pedal so high..
Thank you
If you want something more advanced you can look for a Healtech QS. You can adjust the shift pressure feel and program the actual cutting time for different rpm’s with Bluetooth on your phoneSorry for being digging this post! But would you prefer Contiroll over OEM? Because I have OEM but the shifter feels a little harsh. (I've set it at 279mm instead of 269mm) because I dont like the shift pedal so high..
Thank you
I’ve bought a Shifting controll for testing, if it feels harsh too I’ll try something strain gauge to see if it is better. These Healtech can fit in the stock connection?If you want something more advanced you can look for a Healtech QS. You can adjust the shift pressure feel and program the actual cutting time for different rpm’s with Bluetooth on your phone
Dear god! That is moto GP level. I'm scared, I just want to ride my bike ;-) LOLIf you want something more advanced you can look for a Healtech QS. You can adjust the shift pressure feel and program the actual cutting time for different rpm’s with Bluetooth on your phone
Yeah they come with a adapter loom for the bike of choiceI’ve bought a Shifting controll for testing, if it feels harsh too I’ll try something strain gauge to see if it is better. These Healtech can fit in the stock connection?
The trigger needs 160NM of pressure to activate, so it is already a good pressure to make the gear engage fully.I would expect a switch that triggers earlier to be worst
If the switch triggers later you have build up more pressure on the shifter so once it triggers it is more likely to go fully into the next gear.
While if the switch triggers earlier I could imagine it cutting power but you won't go into the next gear because you might have stopped pressing already or the pressure is not enough and you end up in the ugly "in between gears"
Was the first change I did when I bought mine! OEM kit bought quite a bit cheaper on EBay off a guy who bought the wrong one for his older 650 by mistake.What a blast!!!
Do not hesitate it's a must
