- Aug 4, 2018
Just reading the posts on fitting the gear indicator. Is it possible to fit the indicator without removing any panels. From what I can see some say yes others say no. The bike I have is new and don't really want to remove any panels.
I didn't remove a single fairing to install mine down the left side (2014 model).Just reading the posts on fitting the gear indicator. Is it possible to fit the indicator without removing any panels. From what I can see some say yes others say no. The bike I have is new and don't really want to remove any panels.
Can anyone confirm if there is anything suitable for the 2018 model CBR650F ABS? All searching online shows units compatible with bikes up to 2017 but none specifically reference the 2018 model.
Fail to see why they wouldn't fit the 2018 but don't want to waste my money...
IDEA, cheap and works.
For my height is in my line of sight , is almost the same angle of the dash just a little forward , but because is retro illuminated you don't have any problem reading it , for the contrary it helps on direct sunlight conditions to easy reading ( giving to the gear indicator some shadow )I had thought about that location but I opted to put up on the handlebar. It's within view without having to look down at it. But you did a nice job on it.
Do you know if this works with clutchless shifts? Not quickshifter but clutchless.I don't need a gear indicator.. that's what I thought until I hit the race track when constant attention on my riding is required at all times. I decided to get one but Healtech is insanely expensive. Not a fan of Chinese knockoffs due to past bad experience, still I gave it a try as it cost less than USD17.. I decided to attach it next to the ignition switch using Velcro and surprisingly it turned out very well..! Wires are hidden neatly and looks like part of the motorcycle.. Feeling racey I decided red. Besides that, other colours was taken by the turn signal, high beam and my tire pressure monitoring. Lets hope this Chinese knockoff can last some time.. Cheers
Yes, clutch use will have no bearing on its function.Do you know if this works with clutchless shifts? Not quickshifter but clutchless.
