- Feb 6, 2015
Velcro fairings? Are they the black ones in between the fuel tank and the outer grey fairings? My apologies -- clearly I'm still getting familiar with this bike.
I have no grey fairings, but yes I believe so. You will see/feel/hear it when you tug on them.Velcro fairings? Are they the black ones in between the fuel tank and the outer grey fairings? My apologies -- clearly I'm still getting familiar with this bike.
Yep, as stated in the thread, definitely not a must have. Just a nice to have.When i first got my bike it would have been nice to have one.Now i just listen to
the engine and i know what gear i am in 99% of the time.I would really like a oil gauge,it
is such a pain in the ass to check for low oil.
Agree with you on that.Yes,not just oil temp.if i am low on oil,without checking oil qty. on the dipstick.
I put this one in under 5 minutes. longest part was to route the cable. Just connect it to the diagnostic plug and program it. For programming you either need a rear stand to do it on the spot or ~1/4 mile stretch with no stops to do it while riding each gear on the minimum rpm. I programmed mine inside my neighborhood, did not have my rear stand yet when installed.1/10
Waterproof Plug and play 1-6 Level Red LED Motorcycle Gear Indicator For Honda
EFI Models
looking to get one but says only for 04-16 on ebay anyone fitted to 17-18 and are they plug and play
Whats the difference between that one and Healtech Gi-Pro DS (GPDS-H01-WH)?View attachment 141 Scored this on Amazon. Plug and play in the data link conector; just required calibration on the bike stand. Crazy that any motorcycle with an ECM would not include that data in the cluster. Three things in my book that should be standard are (1) adjustable levers. (2) ABS (3) gear indicator. They are just being cheap.
Seemed like the Healtech makes your wallet about $40 lighter. Other than that, probably not much. They both plug in the same spot and show the same thing. Maybe someone else has some insight that bought it?
