GoaCBR
- Feb 1, 2016
I have fitted a Healtech Gi-Pro DS (GPDS-H01-WH) Gear Indicator. Comes with various colour display options, I went with white, this is easy to see even in broad daylight and fits in with the Tri-Colour. This is simple to fit and comes with a connector to join up with the red Diagnostic plug under the seat. I ended up cutting the wires so I could thread the wires through the meter cover and then joined them up under the seat. Made it easier to route the wires using existing wiring route and slipped under the tank cover as well .
Makes a lot of difference especially in slow traffic as well as at high speeds. No more searching for seventh or stalling because I was crawling in fourth.
The meter cover seemed the obvious place to put it and made it easy to hide the wiring, although would have preferred one as part of the LCD dash display, but as that is not the wish of the Honda designers....
