Speed does indeed do it!My last tank was all (fast) highway miles filled up this morning after 142 miles. 3.4 gallons just under 42 mpg… I did lube my chain last night. It really needed it maybe that will help. Though I think the speed is the main factor 😉
Yea, I was a bit above that speed 🫢Speed does indeed do it!
Wind resistance goes up as the square of the speed so double the speed and 4 time the drag!
So even quite modest increase in speed like 70-90 mph will have a big effect of MPG.
As I found chasing my son on motorways 👍
Likely just the right handgrip, like me 🤐I wish I could get the MPG some of you guys get! I routinely get about 30 mpg on the highway going 85 MPH. 65 MPH will get me maybe 45 mpg. The only way I can get 55-60 mpg is if I ride very sedately at 45-50 MPH on a flat road.
My long-term average is about 35 mpg. I ride a bit aggressively, but I don't drag my knee or anything like that.
Wonder if something on my bike needs adjusting.
Something seems wrong here. I'm geared at 14/43 and will routinely cruise in excess of 9k rpm and well past 80-85 mph and still get at least 44mpg.I wish I could get the MPG some of you guys get! I routinely get about 30 mpg on the highway going 85 MPH. 65 MPH will get me maybe 45 mpg. The only way I can get 55-60 mpg is if I ride very sedately at 45-50 MPH on a flat road.
You first need to allow for the difference between US Gallons and Imperial Gallons (UK)Something seems wrong here. I'm geared at 14/43 and will routinely cruise in excess of 9k rpm and well past 80-85 mph and still get at least 44mpg.
How many miles do you have on the clock and what air pressure are you running? Low tire pressures or fouled plugs would be my only guess as to why your getting such poor mpg.
Yes, a long term average of 35mpg is really low compared to mfg stated and others actual results. In order for me to get 35mpg I'd have to forgo using the last 2 gears and even then it would probably be a struggle. 35mpg on public roads is very low.You really think he’s that far off? I personally find the mpg calculator on the bike to be remarkably accurate. When you take it up to 12k rpm, I’ve seen it read as low as 10 mpg, and in that instance I believe it. I have also seen it go up to 90 when coasting downhill in a draft. Depending how he is driving and the roads I don’t think there is anything wrong with the bike.
Like I said for me last week, I averaged 41.7 with speeds somewhat higher than you mentioned.
Is there a chance you accendentilly did some damage to the sensor in the exaust? resulting in the wrong amount of fuel to air ratio? Maybe the spark plug colour can give some feedback?I added a full exhaust to the bike
I never trust the bike's computer. It's a novel addition but it's not accurate for true comparison. Next time you fill up measure and calculate manually and see what you're getting. That's the true test. I'd bet even with the reduced air pressure you're pretty close to what the rest of the group sees. If it's actually in the mid thirties I would investigate further.I have 7200 miles, and as far as I know, stock gearing. I got the bike at 2000 miles, and it appeared to be completely stock.
I added a full exhaust to the bike, but I didn't flash the ECU or change the air filter yet.
Also, I do run the air pressure 2 psi lower than recommended (so 40 rear, 34 front) because I heard that it helps with grip. Not sure if it would make that big a difference?
Sometimes, I'll rev 1st gear all the way out when accelerating from a stop to 55 MPH. On twisty backroads, I'll usually stay in 3rd gear with occasional shifts to 2nd or 4th.
Just cruising on the highway, however, my bike tells me I only get 29-33 mpg at 85 MPH in 6th gear. At 70 MPH I get about 39 mpg. I have to slow down to about 60 MPH to get 44mpg.
I wish I could get your MPG! I noticed you have the CBR, while I have the CB. Maybe the fairings make a big difference?
Looked up the MPG (UK miles per imperial gallon) on a review when they released the new bikes in 2019 and Honda quoted 4BHP more on both CB650 and CBR650R and a slight drop in fuel consumption to 57.6 MPG so Honda don’t think the fairings affect MPG!I have 7200 miles, and as far as I know, stock gearing. I got the bike at 2000 miles, and it appeared to be completely stock.
