All 650's Accessories plug
Danil14
May 21, 2020
I would like to use accessories port to connect oxford heated grips and wireless quad lock phone charger with the cable, shown below.
Could you please tell me is it a bad idea? Will I have any problems with fuses or something else in this case?
Rafe
Oct 1, 2019
No problems at all. I've done exactly as you've described and it's fine.
TheWingRider
Jul 5, 2019
Stuttgart, Germany
Well this is awkward. I don't see it on my bike at all.
fergard @fergard : Did you manage to find the connector behind the headlight? I have the same 2018 CBR 650FA model and would like to connect my navigation device. Also, could you share the correct part number or link from Germany for the Sumitomo connector? I know that you have upgraded now, but if you could help me, i would be grateful. On Ebay - I see mostly products shipped from GB.
I would say Honda have just relocated it somewhere else when they redesigned the headlight fixings.
It will be up under there somewhere, the question is where!
As the connector is used by the OEM Honda heated grips, I doubt they will have buried it too deeply (as no one will accept 4 hours of labour to install heated grips, just because you need to remove the headlight!). It doesn't make sense.
My original advice stands ... remove the side fairing panels and have a good look around under there for it!
Brammers @Brammers : Oh my all knowing encyclopedia of CBR 650F knowledge, could you please help me if you now know where this 2 pin accessory connector is? I have huge respect for the amount of things you know about this bike.
On the 14-16 650f it's behind the headlight. On 17-18 ones it's wither there, or behind the left side fairing... I can't recall.
There is another thread on here somewhere with all the details. Have a search 👍
For 650f - CB is behind left fairing, CBR behind headlight.
650R is on left side of Airbox I think? (someone who owns one can correct me :D )
densil101
Dec 19, 2019
Any ideas on how to crimp the connectors? Someone suggested using pliers and a screwdriver but still not quite sure how to do it! Thanks.
GTSnoRacer
Feb 20, 2021
Can someone confirm, there is the 4 pin DLC (red) connector and also the 4pin 12v accessories connector under the seat? And the also a 2pin by the left fairing/headlight ?
Dlc yes, 2 pin yes.
The accessory connector under the seat on the 650f is a 6 or 8 way as it offers more than just power.
Check out the wiring diagram in the service manual for details.
GTSnoRacer
Feb 20, 2021
Dlc yes, 2 pin yes.
Ah, I saw that 8 pin connector but didn't think it was for the accessories, I ordered a pack of connectors but it didn't have an 8pin. Bummer. Was hoping there was another 4 pin tucked away under the seat so I could wire up a USB for pillion heated vest. The installation instructions for the oem 12v socket show a 4 pin on the right side under the seat though? Edit, never-ending that, I see now that I'm looking at instructions for a 650r
