Pompeybiker
Amateur
- Mar 4, 2017
Is there an accessories plug for sat navs or phone charging anywhere on the bike?
Yes, what @miweber929 said.
I ran battery tender leads from the terminals:
Amazon product
Then when you need to trickle charge, simply plug it in.
When you need to charge a device, use this:
Amazon product
I have a USB cable fixed down the side of the bike also. You cannot see the USB cable or the tender lead off the battery unless you bend down and specifically look.
I'd prefer that as well. I wired my led lights directly to the battery also because I couldn't find the right wire to use for ignition switching.Looks like a good option but really want it switchable with the ignition
Yes, but I didn't go this route because I didn't have a way to just splice a positive wire in there due to the specialized port on it.The auxiliary connector under the dash is switched.
You would think... But maybe not since Honda just intended you to plug your heated grips in with the compatible port...?I haven't found from where, but you must be able to.
Looks odd.try again as I just posted in on the wrong thread.
I believe this is the loo. needed to plug into the aux plug. 08E00-MJE-D40 Sub Harness
Cool. So ot would be possible to connect any ol pos/neg accessory to it?
Did you splice into the wires before the end/port?Yes it does, I have it powering all sort it's a decent ampage connection. I have grips, phone, camera, indicator cancellers.
