Don’t worry about it to much, your problem is solved with a new pump. Just don’t agree with only an o-ring replacement, let them know that you know about this issue! The Honda bikes are solid 👊Yeah goblin I think I had been riding for a while with the leak as I never saw any drips on the garage floor. I will contact the dealer. It’s an awesome bike I just hope I don’t end up in an infinite loop of getting new pumps that leak
I’ll make sure they replace the pump, thank you for the advice!Don’t worry about it to much, your problem is solved with a new pump. Just don’t agree with only an o-ring replacement, let them know that you know about this issue! The Honda bikes are solid 👊
Hello.Hey guys, I believe I have this same water pump issue with my brand new 2023 cbr650r 😪. The day after a 2 hour long and very “spirited” ride in the mountains I checked my oil level and the dipstick was dry (coolant level seems to be steady). These pictures show what I found, does this seem to be the same issue and has anyone else had it happen with the 2023 models? Of course I’m well within the warranty but I’m not optimistic about replacing seals or the whole pump after reading this entire thread… This is very frustrating and I’m worried if I’ve done any damage by riding with low oil level.
No, the oil leak tends to migrate through the sump sealing line, because oil finds it as a progression barrier ans travels throug it.Yeah looks like your pump is leaking oil, but I also see some oil coming out of the oil sump sealant. Let the dealer sort it out. If your dipstick is dry then the bike is leaking for some time or the oil level was low to begin with. Glad the bike is still under warranty!
Agree with the fact that replacing the fitting O-ring doesn’t fix it.Don’t worry about it to much, your problem is solved with a new pump. Just don’t agree with only an o-ring replacement, let them know that you know about this issue! The Honda bikes are solid 👊
Do you expect others will do better?! Hmm, not sure they do.Sup y’all!
Interesting reading this tread. I have a 2015 CB650F with 70k km and with the infamous droplet of oil. Living with it, but this will be my last Honda.
It’s your choice to swear off Honda but just to be clear the “infamous” droplet of oil due to a poor water pump connection is a ‘19+ phenomenon and normally doesn’t affect the 14-18 models.Sup y’all!
What I experience, for the 2nd time, is not a fitting leak. It's a pump shaft seal leak. I was able to confirm that the oil is comming from the weep hole. But in the replacement pump, the leak is really minor. I can only see the bottom pump screw is oily. Nothing major. Apart from that, the bike has been totally fine after 29kkm.It’s your choice to swear off Honda but just to be clear the “infamous” droplet of oil due to a poor water pump connection is a ‘19+ phenomenon and normally doesn’t affect the 14-18 models.
With 70k km, or like 45,000 miles, on an almost 10 year old bike I’d say an easy to change water pump is a minor repair, and hardly indicative of a massive issue. My ‘16 Silverado with 105,000 miles on it just needed an alternator that i installed last week, I wouldn’t not buy a Chevy because of that. Waterpumps, alternators (or stators), tires, shocks, bearings, bushings and brakes are all pretty much wear parts.
But that’s your call to make.
Maybe it is just an excuse to try the mt09 😅Do you expect others will do better?! Hmm, not sure they do.
You don’t need an excuse to ride a CP3 Yamaha. Just know, though, you’ll buy one after, just be prepared for that. I don’t think there is a much better engine in motorcycling. Probably ever.Maybe it is just an excuse to try the mt09 😅
