Luggage Givi top box rails with R&G tail tidy
Drivinggod666
Aug 24, 2020
Hi all
just got my cb650f and tried adding a set of givi rails for my monolock top box. Problem is the R&G tail tidy makes it impossible to mount the rear bracket. Anyone else got this arrangement? Or should I look for an alternative tail tidy.
I can add pics if needed?
Cheers
Mar
Drivinggod666
Aug 24, 2020
Better late than never. I’ve got around to trying to fit the givi arms again with little success....
If I remove the R&G tail tidy. The givi rear backet fits ok. But I can’t get the tail today back on.
I’ve never seen the stock tail tidy. So not sure on the differences.
Anyone else got this configuration?
Any help much appreciated
Patent
May 19, 2020
Would some spacers and longer bolts create enough room below the givi brackets for the tail tidy to sail under other bracket?
Alternatively I think the Shad setup is slightly different and wouldn't clash
Drivinggod666
Aug 24, 2020
Cheers, I’ll see what I can find. Got the top box already from a previous bike. So would be better if I didn’t have to buy it all again. I’ll post how I get on. Thanks again 👍
Drivinggod666
Aug 24, 2020
Afraid not. Lost the will. But I need luggage for this spring summer. So I’ll have to pull my finger out soon! I’ll post if I make a breakthrough
Drivinggod666
Aug 24, 2020
Did you manage to sort this? My bike came with a tail tidy fitted and I'm thinking of getting a top box for it.
All sorted . Just needed to create some extra space for the givi bar that goes across the back.
Used some washers underneath the tail tidy to give it some extra clearance. Looking good now.
Patent @Patent - thanks for the idea 💡
