okThink i came off more passive aggressive than intended, apologies
If your having problems with false neutrals on a Supersport the following things will help:Can't speak for the CBR650R yet, but as long as it isn't as bad as the Ducati Supersport I am sure I can work with it.
the following thugs will hell:
Oops, freakin autocorrect......Well, there's no need to get your thugs involved.
My gear never wobbles ! The pressed like you say looks wornIf your having problems with false neutrals on a Supersport the following things will help:
1. lower the shift lever as was suggested for the 650.
2. Let the transmission break in before using the quickshifter a lot
3. There’s a tech bulletin about raising the oil pressure on the clutch plates
4. You may have a faulty quickshifter
5. There was a recall on the shift lever for an improperly pressed tip on the lever, that may be moving.
One or more of those should help. Otherwise see your dealer, there’s been a report or two of shift fork issues. Once broken in, they are great transmissions.
I was discussing issues with the Ducati Supersport, much different system than the 650 has.I have that
All I would say is I can't recall having trouble changing gears on my 2018 cb650f. Is the clutch adjusted properly?I have a 2020 cbr650r and have had frequent false neutrals.
I do believe that the cbrs (in general) are more prone to this happenning.
I remember a youtube video - where I believe MaxWrist was test-riding a new cbr1000rr and got the same false neutral I get.
It was funny because he ended up "grinding" it back into 2nd gear and almost giving it a WTF kind of reaction - like I do when it happens to me.
I find it extremely annoying.
I think what makes it happen for me, is that I need to be more aggressive with my foot on the shifter when dancing from 1st to 2nd and 2nd to 1st.
I have no shift issues between any other gears, but I think there might be more "travel" between 1st/2nd on the CBR than on other bikes.
I don't know, but the false neutral is super annoying - and in one instance was dangerous, as I was in neutral instead of a gear, rounding a corner - trying to get it to "grind" into an actual gear. Not pleasant.
Also don't know why trying to click it into a gear (from neutral) - at speed - causes it to make that harsh grinding noise, either.
(Same happened to MaxWrist, too - so I know it is not just me).
Oh well - enjoy your bikes, guys !
