All 650's Cb650f 2016 Rear brake binding
CB650Frider
Jun 19, 2026
Hi all New here bit of back story I bought my bike 5 months ago 2016 Cb650f Abs
In thr black and white colour combo with only 5k miles ever since buying it the rear brakes been an huge issue it's fine when cold but after 5/10 minutes of riding it starts to binde and come on harder and harder but when you press the brake pedal the brake come off aka it releases pressure so because of this it cooked the disc and rear caliper
So I've replaced the disc caliper all pins, pads still nothing so I've just rebuilt the mastercylinder and it was filthy had so much gunk inside of it, cleaned all of it out new seals and spring thinking it would solve all of my problems but it's still doing the exact same so I'm at a loss there's literally nothing else I can replace.
I'm an ex car mechanic so I have a good idea of what I'm doing but this has completely baffled me so any help or pointer is more than welcome at this point I just wanted a low mileage example so I wouldn't have to deal with anything...
Welcome!!!
If it takes 5-10 minutes it’s dragging so I’d start with adjustment of the pedal height and activating rod. Link to the service manual is in the resources section, take a look at the rear brake section, see what you find there and come back with any q’s.
CB650Frider
Jun 19, 2026
Thanks for the welcome!
So I've played with the peddle hight and... it didn't make a difference but something that I failed to notice was that the whole foot rest and bracket is actually bent so where the rod connects the rod has approximately a 15/20 degree bend,
So to test it out I've disconnected the rod completely and rode for about 15 minutes absolutely no brake binding or anything.
I've now ordered a whole footrest and peddle online and that should finally be the issue solved 🙃 but hay atleast the whole rear brake set up got a refresh in the process 😂
I will make another post when the new units fitted and whether that's truly the end of it.
