CB650F Bought bike, cranks no start. 2 ecm wires cut
N8dogg79
Jun 5, 2026
Tennessee
I’m sure this has been asked a million times. I bought an 18 650f for $600. No title, got a bill of sale. Ran VIN and it’s clean. The problem I have is it cranks all day but won’t start. Pretty sure it has been dropped or laid down gently. The clutch lever is bent and some of the side fairings are missing. Gone through and checked all connections and seem to be good. Gapped the plugs and checked for spark. It has spark and fuel. All electronics are working as well. Jumped the tilt over switch connection to make sure that wasn’t the problem. The only other issue I’ve found is 2 wires coming out of the grey harness connected to the ecm. The pink/white wire is cut and the purple/red wire is cut also. I feel like it’s something simple but not sure. Any help would be greatly appreciated. Could it be the valves? Someone mentioned that and I’m not sure what that would cause as far as a no start issue
I've followed the wires on the diagram ... those two are for the MAP sensor and the ECT sensor. Both affect fuelling.
You'll need to reconnect those. I'm surprised the bike isn't showing a MIL code at this point!
N8dogg79
Jun 5, 2026
Tennessee
Update. After further vin inspection, the bike was stolen in 22. Has a salvage record. So I’m thinking these wires were used to Hotwire it. How do I fix these. Can’t find the other ends in the loom
They will be there.
Ect sensor is (going on memory) located on the rear of the engine, the map sensor is on the rear of the airbox.
Both wires will be in the loom somewhere!
I'd unwrap the ecu loom and find them by going backwards.
N8dogg79
Jun 5, 2026
Tennessee
New update. Replaced the main wire harness. All plugs connected and run nicely. Also changed the coils and plug wires. Still just turns over all day and no start. It does backfire under the air box. What else could be the problem. No cut or janky wiring now
If you have a backfire then you have fuel, air and spark... So it should run.
The 650 uses lost spark ignition, so I'd double check that plug wires are in correct order and to correct packs, and that the low voltage input to the coils it the right way around.
Almost feels like it's firing on the intake stroke.
N8dogg79
Jun 5, 2026
Tennessee
I’m good with cars, learning bikes. Which is the low voltage plug? Has a new wire harness now and new coil packs. Just just fires in the throttle body. If feels like it’s simple but not sure. Someone mentioned it could be the valves? Does that sound like a possibility? I feel like it would still run rough, if the valves needed adjusting
The low voltage wires are the wiring loom side of the coil pack... Not the plug HT wires.
The valve timing would be so far out to do this I doubt it's that... The engine would be almost trying to run backwards at that point.
You know you have spark, air and fuel... I just feel like you haven't got them in the right order yet.
I'd start by being very sure that coil pack 1 & 2 are not swapped (check using wire colours from the diagram) ... this bike fires the cylinders in pairs, but only one cylinder of each pair has compressed fuel in it at a time (the other being on the exhaust stroke). Also double check that the correct plugs are on the correct coil packs.
If you've got this mixed up, it's possible that it's firing on the intake stroke, which would become a massive backfire event.
HTH
