- May 16, 2017
Can you guys really beat this sound?
Good old Termi.đ
Akro is over rated in my opinion and a rip off.
The build quality looks better on the two brothers in my opinion.
With that money i will buy akrapovicThis is the best exhaust I have found for the 650F......
https://www.ebay.co.uk/itm/Honda-CB...107836?hash=item236b8ab53c:g:oNcAAOSw8RJXBhP2
Ok, Iâll bite. Iâm not going to debate with you on whatâs better because Akra is one of MANY exhaust makers that have good products but your complete argument against them is unbelievably unfounded so I want to clear a few things up.
Google these two searches:
âTwo Brothers exhaust issuesâ
âAkrapovic exhaust issuesâ
Now come back and talk to me.
TBR has ALWAYS had had issues with their carbon fiber cans literally blowing apart, poor quality welds, crappy mounting hardware and their warranty department is awful. Also, they donât, and neither do a lot of companies, design an exhaust specifically for each bike and test it so it will actually make more power than the stock bike does and not hurt it like most do.
So Two Brothers takes âxâ muffler off the shelf, fit a set of headers to it, make a link pipe and call it good; if it makes power, fine, if not, thatâs fine too. Thatâs why they almost universally tell you to get a PCV with a map and Akra doesnât. Akra looks heavy because of the size of the can but itâs not because of what itâs made of: titanium.
Oh yeah, Two Brothers need to be repacked every 10k miles it 2 years, something crazy like that. My Akra? Good for life. Not hard, not expensive, but not fun.
Until youâve owned, installed, worked on, crashed with it, mapped, called tech support, etc. on other companies pipes, you will feel that Akra is overpriced. Thereâs a reason they are what they are and stay in business when so many others have folded. TBR is a fine pipe, IXL is fine, CS Racing s fine, others are fine, but thereâs a reason they are cheaper than Akra, Arrow, Yoshimura, etc.
Little known fact: in the mid 90âs to early 2000âs Honda factory racing here in the US was sponsored by Jardine exhausts. You know what they actually used? Rebadged Akra because they worked better and didnât blow apart during a race on the RC51âs.
People have done that with varying success. Search around the exhaust section a bit, youâll, find them.Can you add a slip on, on the cbr 650f by cutting the existing pipe (as it's one whole system) and then installing the slip on, onto the exiting system pipe, instead of installing the full system? Or will this affect the performance or the engine?
Yes you can. I've had both types. Cut the stock pipe and add a slop on and now I run the full Akra system. In my opinion the slip on is a better option. The stock headers are the best and the end can makes little to no difference to the performanceCan you add a slip on, on the cbr 650f by cutting the existing pipe (as it's one whole system) and then installing the slip on, onto the exiting system pipe, instead of installing the full system? Or will this affect the performance or the engine?
Hi I am also looking to get an after market exhaust for my 2015 cb650f...but looks like no avail...just purchased the new US 2018 cb650f. I'm looking for an aftermarket exhaust but I haven't seen any options. Would any other year exhaust fit the 2018?
All the models look the same and have the same specs. Any help Is appreciated
Hi there...is there any chance for a link...If you're prepared to spend ÂŁ700 on the CS racing exhaust it may be worth waiting for a discount code to come around for a retailer that sells the Akrapovic one. It really is worth the extra money, the quality, fit and finish is fantastic.
i have the same year, 2018, equipped with full Yoshimura R77, comes with db killer but not installed. Most everything is louder than stock; PCFC. Yes, 4hp isnât a lot but it puts the F on par with the stock Râs, considerably lighter, and a lot less heat under the engine.They should be all the same.
the new pipe is louder and about 4HP up on the on the <=16 one. meaning after market pipes will not give that much more power but more noise (well, a little less, relatively).
