CB650F Tuning for full exhaust?
GregThatBikeModGuy
Nov 20, 2024
I recently got aftermarket full exhaust for my 2016 honda cbr650f. Do I need to tune it? I heard the engine will run lean and get damaged if not. I did buy a dynojet commander 6, but I woudl have to learn how to tune with that.
JH09
Jul 29, 2020
Brammers @Brammers did you notice any difference? i have not had it tuned after exhaust install, seems fine to me! thanks
JZA
2022
Feb 7, 2024
Did you keep the O2 sensor plugged in after tuning? How’s the fuel economy?
FinCB650R
2023
Jun 11, 2023
Finland
Got a full exhaust without tune, no issues. I am planning a dyno thou, not to add max power but to smoothen the usability as much as possible. CB650R has a little dip on the torque curve around 5-6k, would prefer it not to do that.
theboatguy
Jun 14, 2026
I have a 16 650f and am going to install a aftermarket exhaust as well. Was wondering if I got the commander 6 how do you map it to the right performance. Do I have to send it in to a tune shop or does it do it automatically? Not too familiar with that. It’s also has 27k miles but well maintained. Also if anyone knows when I should have my clearance on my lifter should be adjusted.
You need the map built on a dyno at a shop.
You can get an auto tuner module for the power commander... But it doesn't do as good of a job as a shop would.
Valve clearance checks are every 16k, with adjustment at 32k.
Grab the service manual from resources section... It has all that kind of information in there.
