Did it come in the package? How come there is zero trace of such an important piece on the dyno web site? is it the same for any year model?No, you should have one of these to plug in...
There definitely should be an o2 sensor eliminator in the kit.
The sensor can stay in the exhaust though. It just shouldn't be plugged in.
I got the exact same response... word by word....Just got the following response from DynoJet:
"Thank you for your inquiry. We appreciate your interest and support for our products.
For the modern bikes with closed loop systems we have found in recent testing and analysis that most modern engines now have actually been designed to run at the leaner factory settings. In the closed loop area of the fuel curve we find they generally run better if the factory closed loop system is retained and not changed. That area is generally very low engine load conditions at the low rpm and throttle, so it does not require substantial fuel changes to run optimally like the high rpm, high throttle settings do. Due to this and ever tighter emissions regulations at the state and federal levels we now recommend the factory closed loop O2 sensor components be left connected, and if using our Auto Tune it would only make adjustments outside that area where they are truly needed for the high engine load conditions at higher rpm and throttle settings. Leaving the factory sensors in place and installing the Auto tune for fuel adjustments outside the closed loop area actually gives you the best overall compromise between fuel economy and power and performance when actually needed. You get maximum economy in the low rpm throttle range, and max power and performance in the high rpm, throttle range."
what is your current bike setup?need PCM for my CB650R, anyone know when these will be released.
Dont waste you money!... I am already regretful. It Doesn’t do anything substantial to your stock bike if you are a daily commuter. it may slightly change your bike’s behaviour at higher revs unless you get custom tunned dyno map. I strongly recommend downloading the power commander app and a map before purchasing any. you will find what I mean. If you think your bike is running lean, all the maps are much leaner at low rpms. .. so I dont see any point to pay that much money + installation (if u are not a handy man) . Its not a day and night change at all!!! at least with the generic maps on dynojet web site. The only use of it for me was adding more air to my mix at 0% throttle to reduce pops and crackles....All standard CB650r
Wow.. I was about to buy the PC5 this month. I did alot of asking around, the feed back is generally positive.. Hmm.. Now I am in doubt. I am using the Akra full system planning to custom tune it. Will it be ok?Dont waste you money!... I am already regretful. It Doesn’t do anything substantial to your stock bike if you are a daily commuter. it may slightly change your bike’s behaviour at higher revs unless you get custom tunned dyno map. I strongly recommend downloading the power commander app and a map before purchasing any. you will find what I mean. If you think your bike is running lean, all the maps are much leaner at low rpms. .. so I dont see any point to pay that much money + installation (if u are not a handy man) . Its not a day and night change at all!!! at least with the generic maps on dynojet web site. The only use of it for me was adding more air to my mix at 0% throttle to reduce pops and crackles....
With a custom map probably?!If you have an Akraf itted, a pc5 will make a noticeable difference.
Did u do what I told you? Download and analyze the map. Assuming you have a little knowledge already, it would be easy to read. Btw, your o2 sensor is capable of adjusting the AFR to some extent which is quite enough to what you have done ( no high flow air filter, right?). Wait for a year for your warranty to expire, and then either flash your ECU or get pcv if you were still interested. Read my words, it is not as noticeable if you are a daily commuter.Wow.. I was about to buy the PC5 this month. I did alot of asking around, the feed back is generally positive.. Hmm.. Now I am in doubt. I am using the Akra full system planning to custom tune it. Will it be ok?
It will be fine but be sure you get a custom tune because the “canned” ones you can download are only ok.Wow.. I was about to buy the PC5 this month. I did alot of asking around, the feed back is generally positive.. Hmm.. Now I am in doubt. I am using the Akra full system planning to custom tune it. Will it be ok?
