- Sep 5, 2018
I had been searching for a while to find a set of turn signal mirrors for my bike. I found these will searching around eBay and the bolt size, spacing and the mirrors mounting angle all checked out. I received and fitted the mirrors and a signal relay today (relay is under the gas tank, a total PITA). Thought I'd share in case someone was searching for something similar.
https://www.ebay.com.au/itm/Motorcycle-Rear-View-Side-Mirrors-LED-Turn-Signals-Light-For-Suzuki-Yamaha-Honda/263833718363?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
They work well, led is visible from wide angles. The mirror is a reasonable size although you dont get as good a view as the Honda OEM's. Now im just wating on some fairing mount blanking plates to dry.
