Are you saying Honda don't recommend the best type of oil for their bikes ?!3rd party oil absolutely better than oem oil of Honda. Keep working with easy maintainance job, you will love your bike more than before![]()
Why would Honda recommend a grade of oil that is not the most suitable for their bikes?!It must be different in each country but if it is like the way it is here in AU, I wouldn't trust the dealer workshop at all. My dealer did the 1st service @ 1000 kms and said that it didn't need anything until 12000 kms. I just replaced the oil with Castrol Racing 1 Full Synthetic 4w50 and the difference is like day and night. It runs much much smoother now, same goes for the clutch.
I agree with Brammers 10/30 10/40 should just about cover most climates. Honda dealers don't always use Honda oil, my dealer uses Motul, I supplied my own Castrol Power 1 s/s. Major improvement on gear shift btw.Wow, 4w50 is a bit off the beaten path. I'm hoping that's a typo for 5w40?
If not, should actually hurt performance as the hot thickness (50) is much higher than stock (30). Unless you're in very hot part of AUS, then it makes sense. But then if that hot, why the low cold weight (4)?
Fully synth oil can help a bit. Honda would always supply oil that is "good enough", but doesn't stop other oils being better.
I noticed an improvement going from Semi-Synth to Fully-Synth. My Honda dealer used Castrol Power1 4T anyway. I would expect 10w40 to be the ideal weight in a warmer climate. Happy to be corrected by someone who knows more than I do.
Good answer. I can understand these sort of replies !
A good question brings a good short answerGood answer. I can understand these sort of replies !![]()
BelRay is a very well known brand in North AmericaI'd go with motul only because it's a few cents more and I recognised the brand.
All of them look ok by the specification.
Honda did not use their oem oil for their racing team, they use repsol instead haha.Are you saying Honda don't recommend the best type of oil for their bikes ?!
but 4w50 was mentioned which isn't the grade Honda recommend !Honda did not use their oem oil for their racing team, they use repsol instead haha.
10w30 API SL is not sound good to me.I tried it with Honda Winner - an underbone 150cc motorcycle and what the oem oil delivered at that price didn't what i'm looking for. In the same price tag you could find better oil. They don't own an engin oil company, they have to buy it from supplier. Motul, Silkolene, Castrol,Amsoil, Mobil,Repsol... have a long time developed oil products, try 1 of their best product.You will get the instance result after switch.
Maybe we have a misunderstanding here. I mentioned 3rd party engine oil have better product compare with the OEM engine oil, not about the recommend vicosity from Honda.but 4w50 was mentioned which isn't the grade Honda recommend !
i think ambient temp really a factor we should care when we chose oil grade.Having recently been educated on oil and it's science, using 10w40 is Ok (Honda spec says so) climate has nothing to do with it. Oil grades are measured at 100c so ambient temp doesn't play a factor (unless your bike has a knackered cooling system).
10w30 will give optimum engine performance.
10w40 won't hurt the engine, but will consume a little more power to pump it around as its "thicker".
