- Thread starter
- #21
- Jul 14, 2020
- Riding Since
- 2015
Oh damnthat’s definitely louder than mine haha!@adammatheww I've got the same bike and recently fitted a Black Widow full system (this one). Did 4.5k miles with stock exhaust and never heard anything like this, so I'm convinced it's the new one.
I'm getting the ECU reflashed on 5-May and hope that will fix the problem, so will let you know. Took this video immediately after firing up on an early Spring cold morning (couldn't upload the video). Choke is active so it's a more pronounced noise (didn't note the revs), but it's audible in all gears when riding and the tapping speed increases with the revs.
I'm determined to solve it - definitely not something I'm happy to live with as it's taking some of the joy away from my new exhaust, and riding in general because I don't know what it is.
I'll let you know if it's sorted in a couple of weeks, but have you had any joy getting rid of it?
(I also replaced the gaskets and torqued to spec when fitting.)
I’ve learned to live with mine now but it’s pretty subtle and only really noticeable if you’re listening for it, assume it’s the nature of the engine
Sounds daft but can you hear roughly where the noise is originating from? To me it sounds like there might be a leak somewhere in the exhaust system because it’s so loud, did you use the glue stuff at each part where the exhaust connects together? Can you feel any parts of the exhaust where air is coming out (other than the end pipe)? Other than that might be worth just buying a cheap new set of manifold gaskets and just doing it again just in case one failed or has slipped out of place, failing that I have no idea mate😬
