CBR650F Rough shifting
Ridenphd
Jan 27, 2024
2018 cbr 650 F 24000 miles. Down shipping into 3rd, 2nd and 1st from 4000 RPM and above, it seams very rough like the clutch is dragging. Certainly not smooth. So I replaced all the clutch plates and disc's ( the whole clutch) adjusted the levers to proper spec. Still the same. When the revs are low 2000 or so it down shifts a little smoother. Is this the way all of these bike shifts? Or maybe it's the clutch cable is stretched a bit. Just wondering?
Ridenphd
Jan 27, 2024
Going to suggest something "out there"... Is the gear lever height in need of an adjustment?
That helped me.
I checked the clutch basket when I replaced the clutch it was pristine. I did adjust the shift lever so I can some what easily get my boot under it to shift up and over it to shift down. I did not adjust the the top adjuster as the shift mechanism is still with the alignment marks where they are supposed to be. The rough shifting is still the same as when i received it. So really dont no that there is a factory setting for the lever itself. I will certainly check the service manual. Are you stating your bikes shift smoothly down where it does not feel like the clutch is dragging like mine?
I don't have a problem that cannot be blamed on me and a bad foot position on the lever. The gearbox is smooth.
Have you tried charging the oil for a different brand? What oil is in there?
45k miles on original clutch here.
Ridenphd
Jan 27, 2024
Amsoil metric motorcycle 10-30 oil changed less than 3000 miles ago. It always down shifted hard at relative high rpms. I bought it at 8300 miles and it has 24000 miles. Just wondering if it's just mine or all of the CBR 650F down shift smoothly?
I think it's yours for some reason, there haven't been widespread reports on here over hte years of rough downshifts.
You could try an oil swap for a different brand - some people have reported that making a massive difference.
I use Castrol fully synth, Motul has also been recommended by others.
There's a ton of oil threads, have a read. It might be an easy $40 fix.
Honda gearboxes, especially the 4cyl bikes, are almost universally smooth shifting, and as Brammers @Brammers has said we’ve had little to no reports of poor downshifting that wasn’t related to rider process, gear shift positioning or clutch adjustment. Not to say there can’t be, just that’s it’s not a widespread issue.
Not to start an oil thread, and this is my opinion only which you are more than welcome to dismiss, Amsoil is not good oil, especially in motorcycle gearboxes, and can cause poor shifting, especially as it wears. It’s made, or at least used to be, a couple hours north of me, and my dad went through a phase many years back where it was inexpensive, fully synthetic oil so we used it and I gave up after a few changes because it would look like to started to break down very quickly and my shifting was notchy, clunky and inconsistent using that brand. I switched back to Mobile 1 at that time, have since started using Repsol, Maxima, Shell and Motorex depending on what the bike is asking for, with far better results. He was stubborn and took a few more changes and used up his cases of oil and switched as well and agreed it was way better to not use it.
I‘ve been told I’m wrong over the years by Amsoil lovers, been told oil going from a thick, rich caramel color and consistency to watery black in a matter of 1,000 miles is ”normal”, shifting being off is acceptable, clutch action being grabby is in my head, etc. but far more people who have switched back have agreed with me after they pulled off the Amsoil blinders. No other oil I’ve used, and it’s been almost 50 years of changing motorcycle and car oil, has done that, Amsoil was the only one. YMMV.
Ridenphd
Jan 27, 2024
Thanks for the feedback. I will try the maxima oil give me a bit to get it and replace the Amsoil and I will report back. It is good to no that the poor down shifting is not normal with this bike hopefully changing the oil will make the shifting better. My wife has a 2017 CBR 500 R son has a 2022 CBR 500 R. They both shift great although the wife has the Amsoil n it. We will c.
FogDucker
My shifting got much smoother after switching to Full Synthetic Liqui Moly. I would start with oil swap too as Brammers @Brammers and miweber929 @miweber929 suggested. Btw, crack open your oil filter and check for bronze-goldish glitters.
Sam
Ridenphd
Jan 27, 2024
Thanks for ur response. I certainly appreciate it. Just a note thoufh I always inspect the oil when I replace it. I will pay special attention to ur suggestion. I will get the oil and replaced it probably weekend of the 11th of July as I am booked up and dont have time to get it done before then
Ridenphd
Jan 27, 2024
I did replace the oil with liquid moly. Rode it now for about 300 miles. Really no better. I have checked the major clutch adjustment. The service book just states make this adjustment to make sure u get the proper adjustment of 3/8-13/16 at the lever. So that's good. I double checked the Gear Shift Arm is aligned with its punch mark on the Gearshift Spindle, it is and the measurement from the Shift Arm to the bottom of the tie rod nut is 8.2. That's good. It still the same. Wanted to follow up with the thread.
FogDucker
Does the bike shift smoothly with the engine off?
Does a deliberate rev-match/blip improve the 4→3→2 downshifts?
Is there any difficulty finding neutral?
Any false neutrals or jumping out of gear?
Is the roughness felt through the lever, or is it mainly the bike lurching from engine braking?
Ridenphd
Jan 27, 2024
Engine off. Never tried it.
Rev match. Improves a little bit
Finding Neutral. No
False neutral. No
One thing for sure if 2nd gear is missed i have to just about come to stop to shift it into 2nd. If I don't the shift into 2nd hit so hard it's as if 2nd gear is going to break the teeth off.
Roughness. Felt at the shifter as if clutch is dragging
Bike does not lurch at all
Hope this helps
As a pure experiment... What happens if you over tighten the clutch cable, removing almost all the slack... Does that reduce the dragging feeling/change anything?
I'm assuming you soaked the clutch plates in oil before fitting... I wonder if the old oil has disagreed with them somehow. Maybe degrease them and soak in the new oil? Some people have had to do two oil changes to solve clutch issues.
This still doesn't sound like a typical 650f gearbox.
Finding Neutral. No
False neutral. No
Hope this helps
When you talk about missing 2nd gear are you saying from down from 3rd to 2nd or up from 1st to 2nd? Either way that’s sort of normal, but especially when downshifting. However if you are missing 1st to 2nd often I would start looking to be sure your lever is in a good place, the shift linkage is free moving and the clutch cable also freely moves.
If you rev match, and you should be doing that, and it gets better, it’s as you thought hung up somewhere, at least in my eyes. Running out of ideas if you’ve replaced plates and the basket looked clean. I‘d maybe try a new clutch cable, if nothing else but to rule it out.
What levers are on the bike, OEM or aftermarket?
Crazy question: has the bike been down at all, especially on that left side? Wondering maybe if that shift shaft keeper is damaged and the upper shaft is floating. If you grab that upper shift shaft that the small arm attaches to can you move it in or out more than a millimeter or so? If so pull it out and see if shifting improves.
