- Oct 14, 2015
STEP 1: Buy Smart Moto Blanking plates for the CB/CBR650F from Ebay. (think no one needs instructions for this!)
STEP 2: LEFT HAND PAIR PORT - Blanking plate, two aln bolts with washers
STEP 2: Flip the blanking plate over and use insulation tape on the end where the reed valve screw heads protrude.
STEP 3: Align the blanking plate on the PAIR Port (LH shown here) Try being gentle, once aligned press the plate with some force (do not need to be brutal!). The REED Screwheads will leave a mark on the tape. (picture 2 below has not come out well but you can see it)
STEP 4: Using the marks as guides, start with a 4mm drill, apply light pressure, and create dimples
STEP 5: Keep checking with if the plate aligns, at this point it will not but will give you an idea. Keep drilling using the 4mm as guide in 1mm increments. Below is an 8mm dimple
I had finally made a 10mm dimple, this will give you room to move incase you are slightly off in your alignment.
STEP 6: Check again, usually you feel a 'grippy rubber' when you move the plate over the port, this means you are flush and can not install the bolts. USE THREADLOCK and stop tightening as soon as the bolt stops moving. Don't over tighten!
STEP 7: The removed PAIR valve and corresponding pipes.
Hope this helps anyone who was looking for an alternative way to do the PAIR VALVE REMOVAL
TO BE CONITUED...................................NEXT: K&N AIR FILTER + AIR BOX MODS (PAIR VALVE SUPPLY BLANKING) + PC5 + HEL BRAKE LINES ..........STAY TUNED!
