- Jul 26, 2018
Hello folks,
I recently did oil and filter change and made sure I put correct amount of oil.
However after first long ride, i have noticed oil leaking from dip stick. Thought I might have put too much oil , I did take some out and again check oil level with bike in upright position , it was under high mark on the stick.
The leak doesn't happen when the bike is idling on side stand, only after a ride.
What could be the issue, did I overfill, should I take some more oil out?
It's a 2018 Honda cb650f.
