I find the time it takes the bike to get the engine from cold to normal temperature very long. It's always been like this (before oil/coolant change, pair valve removal or remap).
Because long is relative I timed it... 3 times and put the averages below.
Environment:
Outside air temperature was around 27 Celsius.
Bike parked in garage (not exposed to sun).
Engine did not run in last 12 hours.
0w-30 Synthetic oil (~2500 km since change).
OEM coolant (1000 km old).
I consider normal temperature when the RPM stabilizes at the usual idle RPM (~1250 - 1300 RMP).
This is 3 out of 6 on the temperature clock. The usual running temperature is 4 out of 6.
1. start to 1/6 temp on clock - 83 seconds - Bike revs at 1800 RPM constantly
2. 1/6 to 2/6 temp on clock - 53 seconds - Bike slowly drops from 1800RPM to 1500RPM - engine starts sounding a bit better
3. 2/6 to 3/6 temp on clock - 85 seconds - Bike slowly drops from 1500 to 1300 - engine sounds good - bike is a bit snatchy at on/off throttle (way less compared to pair valve removal).
This adds up to almost 4 minutes.
It takes like another 1 to 2 minutes of riding to get bike at 4/6 where is butter smooth.
Do the numbers match the start of your Rs?
Environment:
