- Dec 10, 2020
- Riding Since
- 2005
Any idea of how to replace position lights?
Thank you for your reply, I checked the service manual and it doesn't include this, I'm referring to the corner light within the headlight, I recon red will look better but not sure what kind of bulb I should get (I'm guessing T10 at the moment), cuz it only says LED in both service and owner's manual.I’m unclear what light you are referring to? Please post a pic. Service manual has complete removal/installation procedures.
Cbr650r / Cb650r service manual (oem)
Oem service manual... The must have item before any DIY work is undertaken!650f.bike
Thank you for your reply, it only says LED in both service and owner's manual so I'm a bit confused.Beside the headlights?
I haven't physically looked at whether they are removable from the assembly on my F model, but it says to replace the headlight assembly.
I imagine it would be the same on the newer models as they're all LED.
Yep, it sounds like they expect you to replace the entire headlight assembly if one fails. You'd have to disassemble it to know if you can install your own LED's, unless someone here has done it and already knows.Thank you for your reply, it only says LED in both service and owner's manual so I'm a bit confused.
