CB650R Evotech Performance Tail Tidy
fnation25
Dec 17, 2018
Thanks for your feedback. How many cables did you have to disconnect in the installation?
LaurenceH
Aug 9, 2019
Bristol, UK
There are four cables:
  1. Brake light
  2. Left Indicator
  3. Right Indicator
  4. Plate light
As a different plate light is used, replacement wiring is provided and easy to fit. All colour coordinated.
User31
May 4, 2019
Edinburgh, Scotland
Thanks for posting these pics! Ordered because of this thread and fitted the EP tidy this weekend on the CBR650R.
After
Before
Looks gorgeous! Could you post an update once you’ve done some wet rides?
This is the best tail tidy I’ve seen, but after EnglishBikerDan switched from R&G back to stock (and some other reports), it’s making me hesitate.
I live in Edinburgh, so wet rides aren’t uncommon...
LaurenceH
Aug 9, 2019
Bristol, UK
Yeah of course no worries mate. Don't often ride in the rain, but when I do I will let you know the results. I expect there will be a lot of dirt thrown up, but that's to be expected / that's the trade off really.
Eaglemoto
Jul 13, 2019
I have to say that even with the OEM plate hanger you get spray deposited on the pillion seat area, so it will only be worse with a tail tidy fitted. Up in bonny Scotland you are going to have more wet weather riding than most, so I would stick with OEM.
fnation25
Dec 17, 2018
Thanks! Had a lot of issues removing the 4 x 8mm Hex bolts holding in the OEM snow scoop. Unfortunately, your standard Allen keys won't do it as they are machined in too tight by the factory. Once they're removed though it was pretty simple!
I've installed it today, I had the same issue with those bolts, holy crap those things were tight, had to go to a mechanic just to loosen those as with standard allen keys it was impossible. Tried with allen keys & hammer and those things were way too tight.
Process is simple, but takes a bit of time specially for a newbie like me.
Alape8
Aug 4, 2019
I installed mine this morning, really like the look of it and having the adjustable arms to fit a variety of plates was a nice touch. No wet test yet... Was dry all day during the ride. IMG_20190830_082427.jpg
The Earle
Feb 18, 2019
Their factory is not far from me, I keep meaning to pop over and pick one up. I have done in the past as it’s a nice ride out saves on postage and they usually give a decent discount.
They also show you around the factory if they are not too busy.
Nice little company, products are not the cheapest but from experience (and I’ve used a few of their parts) they are good quality.
Devilsfan
Jun 5, 2019
Tampa, Florida
This!!! I love it when a company gives you a tour of their facilities. To me it shows me that they trust their product(s) 100%...and so should I. Also, I'm willing to bet their customer service is top notch.
The Earle, next time you're there see if you can snap off a few pictures. I always love seeing where things are made!
The Earle
Feb 18, 2019
Will do, it’s a cracking little business
John876
Aug 6, 2019
Essex, England
I fitted the evotech to my bike yesterday. I didn’t have any problem getting the bolts off like some of the other posters. I used a ratchet set, not Allen keys. Maybe that helps?
It’s expensive for a bit of metal but I think it’s worth it.
Goblin
Sep 2, 2019
Hope this helps :)[/QUOTE]
Got the same Tail and radiator guard from Evotech. Yes the price is a bit steep but the looks and quality are more than making up for it 😁
Jiyuu
Jul 9, 2019
Great looking tail tidy stevelululu @stevelululu !
If I may, what do you mean by "Only complaint I have is that all the cable routing is done in the open"? Is the wiring exposed to the road? Maybe a picture from the underneath would help :)
Also, is the angle adjustable? In France, license plate for motocycles must be angled between 0 and 30°...
Chears
stevelululu
May 7, 2019
Toronto
Chears
Angle is non-adjustable, but you should be fine with the stock angle.
As for wiring, it's just not "enclosed" like the stock fender. There's still rubber insulation around all the wires, so nothing is physically exposed. Just means everything gets dirty with spray/dust/road crap.
Goblin
Sep 2, 2019
The Evotech tail tidy is indeed non adjustable but is within the max 30 degrees angle. The wires are routed on the inside of the tail and hold by clips. I like the simplicity of this tail an it’s the shortest of all tidy’s.
