- Feb 16, 2018
Just let them warm up it's nornal , it's the choke I think, it's a good thing !once it stops high idle that's when you know the oil is nice a warm.
Idle speed is non adjustable, it’s set by the ECU.How many miles has it done? As engine idle speed is something they check at the 600 mile service.
Okay mate cheers well itd a very siamilr thing to choke then as choke richeches mixture toFuel injected motors do not use a choke. They are either in OPEN LOOP when first started which is a pre-programmed richer mixture or once they go into CLOSED LOOP they use the IAT & ECT to control cold mixture until it hits roughly 150 F.
Surely a dealer can still adjust it if they feel it is out of spec.
To explain what I was getting at a little better is the ECU sets the number, say 1,200 and that’s a HARD number embedded in the programming and wouldn’t be “set wrong” for a dealer to adjust. So if you are idling higher than you should it’s because some sensors could be out of calibration and reading wrong, not mis-set. But if that was the case the tach would display the correct idle reading but the engine woukd be actually running higher or lower.
Does it make sense what I’m saying?
It wouldn’t make sense for one bike to have their idle be set at 1,200 and another 1,300, that’s just the slop that’s built into the programming and an acceptable idle variance so there’s nothing for the dealer to change. Unless you have an idle screw like the old FI systems have, the bike will idle where it’s told to idle.
I think you way overestimate the 600 mile service because they change the oil, maybe adjust the chain, hook up a scanner for codes and send you on your way. They do not do any advanced calibration or advanced diagnostics, it’s simply in and out, give me the money.
Ah I see, assumed it was some sort of analogue thing that's adjusted in the old fashioned way, as you say with the idle screw.
Only going on what is on the dealer check sheet of the things they look at during the service, of course that is assuming they actually carry out the check and not just tick some box.
? Nothing wrong with riding a bike when its cold...It makes me cringe when people jump on a cold bike start it up and off they go. Get a car ! Your no biker.
I only have 600k done at the moment. Should have 1000k done by next weekend, then its in for the first service. I will get them to check it out.How many miles has it done? As engine idle speed is something they check at the 600 mile service.
Thanks. May get the dealer to dial it back just a bit.It's 1200 +/- 100 anyway, so 1300 is absolutely fine.
I was wondering where those extra cylinders came fromRight! Not a Harley coughing at 450 rpm
Why?Thanks. May get the dealer to dial it back just a bit.
