- Thread starter
- #21
- Feb 15, 2015
Yes you'll have to drill them out or the switch housings won't sit properly, as above, 5.5mm drill bit if you have one. Only have one chance to get it right so take your time and you should be fine.
I would love a set of those mirrors but too wide for my she'd 😞Yes you'll have to drill them out or the switch housings won't sit properly, as above, 5.5mm drill bit if you have one. Only have one chance to get it right so take your time and you should be fine.
ThanksI would love a set of those mirrors but too wide for my she'd 😞
I'm a bit late to the party...Pictures of the cables below:
Neatly brought together with 3 thin cable ties, a little slack in them for safe measure
x1, 5mm locating pin on the unit which houses the indicator & headlight switch.
The pipe coming from the brake reservoir will be a driving factor in how you angle your bars. Since this needs to be able to flow freely and ultimately be level to display a correct reading, you'll also need to factor in the mirrors you use in terms of the distance this is fixed from the end of the bar.
x1, 5mm locating pin on the unit which holds the throttle cable.
As I'm sure you can see, you can understand why it's a fiddly mod. But as I've said, since this is where all the hand controls are its nice to set them exactly where you like.
Off topic, but since you mentioned red accents aaron, here's something I did last night.
Did you install bar inserts/vibration dampening cores too?
Looking To change my bars to Renthal Ultra Low but wouldn't want to have vibrations..
Got it from www.retrofitlab.comHi Daniel,
Question; where did you buy your headlight ?
I've been looking for something like this but could never find anything online.
