That's the thing I don't know..What is it’s purpose ?
It's the evap can. It captures fuel vapor from the tank and allows it to be drawn through the engine and burnt.
Required to meet euro4+ emissions tests. On a 2017+ 650f it is doable (as the previous models didn't have to use it). The early 650f in Thailand and California did though.
On the 650r, I'd expect a warning light if it wasn't there (again, euro4+ regs).
The engine doesn't need it to run though.
You think that it's safe?🤪If you can join the in and out hoses, it might work!
I need to do some more reading. If you can't, there's stuff under the tank you'll need to remove and tweak too.
If you have time and are willing too, please. Otherwise, I'll give it a shot!
Having had another look at the service manual, just connecting the pipes looks dangerous as it could allow air to be forcibly drawn through the fuel tank into the engine.
To delete the canister you will need to also block off the pipework under the airbox (on the canister side of the solenoid valve).
You will also need to extend the fuel tank breather hose down to the bottom of the bike with the others.
I can't say what that will do to a pass/fail on any annual inspections you have in your country surrounding emissions, but know that your bike will no longer be Euro4 compliant.
HTH
HTH
Today I finally had the chance to remove the ugly EVAP canister, much better now to keep things clean. Capped off the lines on the throttle bodies and extended the evap line coming from the gas tank. Left the solenoid in peace since it's a pita to reach.
