- Aug 21, 2021
- 2021
I can confirm that breaking power increased after 700-800km.
It takes time for the brake pad material to bond with the rotor.Yeah I'm now at 800km, and it seems to be a bit more solid...
Ditto this...I made the choice to upgrade brake pads before my first track day on my starter Yamaha R3 from stock to EBC HH+ sintered brake pads for front and rear. In my judgement, the braking bite and feel went from a 4/10 stock to a 7/10 post install + track day to test. Yes, I also flushed the front and rear systems with high temp resistant brake fluid. In my experience, brake pads and steel braided lines are what improve braking feel as basic upgrades.EBC will make an HH+ pad that will help the power and feel but know all the brakes will have a very “wooden” feel and the back brake is not designed to actually stop your bike, but only to assist the front brake which should be your main brakes. If you come from cruisers or touring bikes, that will take some getting used to.
Hmm...great ideas ! Is it hard to change brake pads ?Ditto this...I made the choice to upgrade brake pads before my first track day on my starter Yamaha R3 from stock to EBC HH+ sintered brake pads for front and rear. In my judgement, the braking bite and feel went from a 4/10 stock to a 7/10 post install + track day to test. Yes, I also flushed the front and rear systems with high temp resistant brake fluid. In my experience, brake pads and steel braided lines are what improve braking feel as basic upgrades.
I firmly believe sintered brake pads are the most cost effective performance mod you can install on just about any motorcycle (yes, there always exceptions). Now although I am not any kind of racer nor have any greater credibility, I felt more confident braking deeper into corners at the track. It is what the club coach was coaching me through anyways. After my epiphany I immediately installed EBC HH+ on my GSX-R 750, massive change. Plan to install them on the CB650R after the first thousand miles. Every rider can and should learn to judge and replace their brake pads
What changed?
When I take a look at the stock pads they appear to be a predominantly organic material delivering a softer feel through the braking stroke and overall smoother ride because softer breaking will not upset the chassis as dramatically as braking with a stronger bite. Sintered pads contain higher volume of metallic particles that create that stronger bite'y feel but they do also create more heat. This is why high temp brake fluid flush is recommended especially if you plan to do back to back track sessions.
It felt like a coming of [age] skill?
When I was more of a beginner it was nice to have softer brakes, now I am comfortable, responsible, and reliable with the brake levers & full suspension stroke I feel as though I have grown out of stock organic pads and will never go back .
How does one "seat" the pads to the calipers? You wear them in! I am out here in San Francisco, so I just roll down some hills stop sign to stop sign to heat them up and wear them in. Yes, I also use engine braking here I am not just jamming on the brakes and calipers.
Naah... Maybe Honda (or Nissin) used a different oem brake pad production method or facility since 2020?Might just be what you're used to from other bikes.
