- Feb 7, 2024
- Riding Since
- 2006
Hi all,
I’m looking into suspension upgrades for my 2022 CB650R. A local shop suggested YSS, but after some digging I’m not convinced. They seem fine, but if I’m spending over $3,000 NZD I’d rather invest in something higher end.
My main driver is weight. I’m 105 kg (about 110 kg in gear), so roughly 30-35 kg over the “standard” rider the stock setup is built around. The OEM suspension has been good, but as my pace increases I’m starting to think it may become a limitation, if not a safety issue. A small front slide mid-corner recently pushed me to take setup more seriously. I’ve already adjusted tyre pressures, may go for a stickier front, and I’m working on loading the front more with body position.
From what I’ve found, Nitron offer components only slightly more expensive than YSS but at a much higher quality level. Öhlins list the STX46 shock as compatible, but the NIX 30 cartridge kit is only shown for the 2019-2020 model. I tried contacting Öhlins but only received an automated “talk to a dealer” reply.
Has anyone else looked into this? Has anyone fitted a cartridge kit to the 2021-2023 CB650R with the SFF-BP forks? Keen to hear what you went with and how it performed.
Nitron:
Ohlins:
australia.tripleclampmoto.com
YSS:
www.yss.co.th
Nitron:
Ohlins:
ÖHLINS - Street S46 Shock (HO 913)
A well-proven monotube design, the Öhlins STX 46 shock absorber sets the standard for performance, quality, and durability. A major suspension upgrade for your Adventure, Street, or Naked Sport Bike. It features a large 46mm main piston, an external gas reservoir, and a manual preload adjuster...
ÖHLINS - Street NIX 30 Cartridge Kit (FKS 516)
The NIX 30 Cartridge Kit is based on the experience learned through decades of testing and racing in top-tier championships. The kit delivers unparalleled performance with stable damping characteristics while ensuring great comfort, contributing to rider confidence. The NIX 30 is designed to...
YSS:
yss-website-front-end
