You want the 7/8" 22mmShould I be buying the Special 1" or Standard 7/8" for the cb650r? (not the riser height but the bar diameter)
Go 7/8 bar size man. Most sport bike accessories are 7/8 diameter as well as bar ends which l am betting you will want to buy and install. Along with the fact its just pointless having Harley sized bars on a 650.Should I be buying the Special 1" or Standard 7/8" for the cb650r? (not the riser height but the bar diameter)
They do look great on the CB650R. In terms of people who have done the mod l feel like a message from @Chen Wetta would be good cause he had the clip on kit with l think a 3" riser and it was amazing!Awesome, thanks guys. A bit new to handlebar accessories so it's great I have your advice.
yeee it was gudThey do look great on the CB650R. In terms of people who have done the mod l feel like a message from @Chen Wetta would be good cause he had the clip on kit with l think a 3" riser and it was amazing!
I use a little Loctite blue, but no lubricant.Hello Dankotaru,
Hello, is it correct to lubricate the various clamping screws on the new aluminum half-handlebars, or rather not? Thanks, bye.
what tightening torques did you use for the bolts?I use a little Loctite blue, but no lubricant.
Thanks, Thanks, but you risk blocking them like this ... I read about copper grease that blocks but does not form oxidation or rust. To what torque values did you tighten the various bolts?what tightening torques did you use for the bolts?
I tightened the fork clamps using the factory torque for the stock clamps, not sure what that is off the top of my head, but it's in the service manual. I just made the riser bolts really tight, and with blue loctite they'll hold fine.Thanks, Thanks, but you risk blocking them like this ... I read about copper grease that blocks but does not form oxidation or rust. To what torque values did you tighten the various bolts?
Thanks!I tightened the fork clamps using the factory torque for the stock clamps, not sure what that is off the top of my head, but it's in the service manual. I just made the riser bolts really tight, and with blue loctite they'll hold fine.
Has anyone tried fitting cbr650f clip-ons above yoke on the cbr650r?"The Woodcraft bars are hollow aluminum"
Hi Dankotaru is it much lighter than the stock? Beside adjust ability, losing weight is a plus point for me.
The forks are much larger diameter on the R than the F since they are inverted and the F units are conventional.Has anyone tried fitting cbr650f clip-ons above yoke on the cbr650r?
Appreciate that thanks.. Did anyone decide the maximum amount of raise the standard cbr650r would take on cables etc?The forks are much larger diameter on the R than the F since they are inverted and the F units are conventional.
I hope this weight loss will to cause you to start fealing vibrations trough the clips.They are about half the weight.
The stock clip-on, grip, and bar end:
Woodcraft 1.5" Clip-On with Driven Racing Grip:
You'll drop about 2lbs when replacing both.
Has anyone tried the woodcraft 1" rise?
I have seen people manage to make enough clearance for 0" rise (Vortex).
I'm not sure if that's easy to achieve with the woodcraft.
What torque specs did you use for the steering stem nut and pinch bolts?While the CBR650R clip-on position is higher and more comfortable than many sport bikes, it's never been especially comfortable for me. Mainly, I wanted a little more outboard sweep, and some down angle would also be welcome. I figure adjusting a motorcycle's grip and control positions to be the equivalent of adjusting the seat and steering wheel of a car, but the stock clip-ons can't be adjusted. So I bought a set of Woodcraft clip-ons. The Woodcraft can be swept inboard or outboard, have 5 degrees of down angle, the bars can be placed to be shorter or longer than stock, and can be customized with a variety of different riser heights. I ordered mine with the same 1.5" rise as stock.
Removing the stock clip-ons is pretty straightforward, and can be done with a 5mm hex, 10mm and 8mm sockets, a #2 Philips. Oh yeah.... and a really big 30mm socket to loosen the steering stem nut:
The bar ends are tough, but can be done with just pliers and a screwdriver. Hold the bar end to keep it from spinning, and remove the screw from the end. If you're not re-using the grips, then you only need to undo the throttle side, so that you can slide the throttle tube off. I have jaw covers for the pliers, but tape can also be applied to the bar ends to prevent scratching them:
Once the top triple clamp and clip-ons are off, you'll see a little snap ring on each tube that is used to locate the stock clip-ons, and they also need to be pulled off:
If the stock clip-ons could have the swing adjusted, I likely wouldn't have bought aftermarket clip-ons. But they have a little extension cast into them that sits inside the top triple clamp which prevents them from being rotated. I suppose someone could cut the extensions off and then re-use the stock clip-ons and reposition them at a different sweep angle, but I wasn't comfortable with the amount of clamping surface area to remove the extension and re-use them:
Woodcraft downward angle compared to the horizontal stock bar is slight, but I find it to be an improvement for my grip:
The Woodcraft bars are hollow aluminum, and I marked the locations of the switchgear and throttle locator tabs with a center punch and drilled them. Distance from the bar ends is all you really need to worry about when drilling the holes, as the bars can be rotated and clamped down in any position you like.
A note about the throttle tube - the stock throttle grip can't be pulled off of it, so it should just be cut if you're swapping grips. Then you will need to cut and sand the plastic throttle tube 'ridges' off. There are videos on the interwebs that show this in more detail, but once the grip is off it's pretty obvious what you have to do to slide a new grip on the stock tube. It took me about 20 minutes with a Dremmel and some 120 grit to get the stock tube ready for sliding the new grip on. I used a Driven Racing dual-compound grip, which I love.
Here it is all back together, but still loosely clamped so I can rotate and adjust everything from the seat:
Once you have it all in the right position, tighten everything down. And then I safety wired the grips, because I didn't use glue and the local tracks require safety wire on grips:
Each piece of the Woodcraft clip-ons can be ordered separately, so if I decide I want a 2" or 2.5" riser instead of 1.5", I can just order the risers by themselves and replace them. Same thing if I drop the bike and damage the bars, they can be ordered separately and easily replaced. And any changes or replacements can now be made without having to remove the top triple clamp. But most importantly, my hand/wrist/arm alignment is now much better for me, and this change has been well worth it.
I found the values, hope this helps anyone else that may come across this forumwhat tightening torques did you use for the bolts?
