CBR650F Will bike run too lean?? Lams
Splint
19
2
Hey guys, I've got a Lams Aussie version and I was wondering if the bike would run too lean if I put an IXL pipe on it before I've got the ECU flashed and velocity stacks all done. I know these bikes generally run lean but I don't want to hurt the engine by sticking this pipe on and I was just wondering if anyone had any experience with this with the Lams version. I've had the pipe for a month (bike for 2 months) and I'm getting sick of the lack of power. I probably won't be doing the ECU etc for at least another month.
Thanks
Mod
1,422
770
#3
You should be fine as long as the other restrictions are still in place.
The pipe itself is not different between the LAMS and non restricted versions so I can’t see where you’d have an issue with installing it. It’s a 4 stroke motor regardless, they can run quite lean for a long time without any issues.
I’d say go for it!!!
Splint
19
2
Thread starter #4
Just so all you guys know, I had to cut 12mm off the header pipe to line up the bolt holes for the silencer (IXIL L3X). And also a little slice off of the heat shield for the coolant bottle top up. But it fits perfectly now ..,
Splint
19
2
Thread starter #5
But.. I think it'll run too leen so... Pulled the ECU and air bagging it off asap to Dynobike as their generic tune pretty much states around 86hp at the wheel. I'm pretty happy with that. A mate has given me his spare Gixxer to help me out. ...Scary AF... But fun...
