Well, that´s funny. Almost every review I saw said it´s unbearable loud inside past 80km/h. They say you really hear the wind. Can´t really compare it as it is my "first real helmet". So I don´t mind because I just don´t know it different. The vents are ok. The front bottom one really makes a huge difference. The front top one....well, a bit. And the rear ones I don´t really notice. Theoretically they should increase the airflow by quite a bit. But like I said, I don´t feel a difference. Maybe also because the full cloth mask I am wearing . Also a little tip: Don´t loose your windblocker for the chin area (not that difficult to loose). You will regret it.@baugustine @h0ck3y @Thomas
What do you guys think to your Qwest, is it as quiet as they say and are the vents easy to use? I'm not sure about the separate exhaust ports on the rear.
I currently have a Shoei GT-Air in white, the vents all work great and are easy to use. It will soon be time to change it and I don't use the sun visor as much as I thought I would and the Sharp rating is only 3/5 so I was considering switching to the Qwest.
For anyone considering a Schuberth, the O/H has an SR1. It's been really poor, the visor developed stress cracks around the pinlock pins and at the lift-up-tab thing. We've had 3 new visors under warranty and the same thing has happened to every one, the lift-up tab also fowled the eye port gasket to the point that it split. The whole lid went away and all they did was fit a plastic clip over the broken gasket.
Can't find fault in that logic. Sounds like you have exactly what you need & want!A little late for the party here, but I'm on my second Qwest helmet and mostly because I did test it on a high-side crash on an older bike (and it worked perfectly at keeping my noggin' safe). Like others, I can't comment too much on how quiet it is because I'm not that familiar with other helmets and I also always ride with ear plugs. As far as ventilation goes, I like the setup of the vents and find it does keep things cool on hot humid days.
Shoei rf-1200
What size are you ?I'd love to try a shoei or arai one day.
Always read good things.
PM meXL
Big Head Life 😎
