- Dec 28, 2018
Hello Everyone,
Last few days i faced a very minor issue, just want to know if any of you guys faced the same.
Issue : There is unnecessary revving in RPM, sometimes very mild increase, and revvs down suddenly once(slight revv down, probably 1k RPM) or twice in one short(20kms) regular commuting ride. I have adjusted the clutch play and Clutch Nut, thinking this might be due to clutch slip, but i have been wrong as this repeated even after the change.
Do you think this needs throttle cable to be checked for functioning and lubrication ? has any one faced the same ? Do i have to look anything else ?
P.S: Happens only when riding in constant same speeds , same gear and same RPM revv range for 4 to 5 minutes.
Thanks in advance
Thanks in advance
