Vaccum hose leading to the map sensor - cbr 650 fa
v4fun
Oct 14, 2024
Good evening, David from South of France. i have a cbr 650 fa 2014 which is about 78000km running on ethanol with a kit
The bikes runs on ethanol for over 70000kms. Ethanol or normal gas is the same the bikes doesn t run well
I has never been running well and I have noticed the vaccum hose leaving below the injection to the map sensor was broken in multiples places and not connected to each other.
It has been replaced and connected together. now the bike doesn t accelerate and an engine fault ligh which for once dissappeared came back.
new plugs,
new air filter,
new regulator,
new lambda sensor changed.
v4fun
Oct 14, 2024
Thanks , I don t have a code reader device. Where should it be connected to?
Just the orange engine light on the dashboard
Look at the service manual... There's a procedure in there to display the code. Chapter 4 if I remember correctly.
It only needs a paperclip as a tool (or length of wire).
v4fun
Oct 14, 2024
I think if I connect the brown and green/white stripe from the code error plug I would be able to know what error it is.
