Hello !
I bought a quadlock USB charger and i searched in the forum , what is the best solution to connect it in the bike.
I saw some people complaining of the battery drain if it is directly connected to the battery.
I saw 2 other possibilities, to be connected after "contact" :
(1) connecting to the accessory plug , which is located in the back of the bike (back right)
(2) connecting in the front left plug , which is normally for Heated grips
(1) I tried first using the accessory plug in the back, but it is impossible to find the name for the connector, that i could use to connected with SAE from Quadlock
(2) In the front left , I removed the fairing from the bike, and I still access to the connector, because i have to remove the fuel tank to see the connector (That i didn't try^^)
This is what i bought for the moment, but it is not ok for the back , and i don't know if it could fit for the front....
And the quadlock that I have
Anyone has a picture for the connector for the Heated grips, or name of the connector for the back., or any solution^^
I checked a lot of French website, to find a connector, really a mess, when I don't have name...
Thanks a lot!
Thanks a lot!
