- Apr 22, 2018
Can anyone help. I have a 2017 cb650f. When I pull away from a start the throttle response is really poor. First there is a flat spot, then it will surge forward so then I have to close the throttle. When you change gears if you haven't got plenty of revs on when you release the clutch you get the flat spot again. Has anyone else experienced a similar thing. If so what's the cure ?
