All 650's Swingarm replacement
Too much carbon ... my plan is to:
Black out the swingarm
Get carbon/carbon effect lower cowl/bellypan
Get carbon/carbon effect hugger & chain guard
Respray in a shade of blue (but not the Honda one Entropy @Entropy has)
A carbon look swingarm would be too much next to the hugger - it's one or the other for me.
I also have some other carbon effect parts to fit into the mix, right baugustine @baugustine ? :)
Ironically, the black swingarm might even be cheaper than the wrap job :)
Entropy
Apr 18, 2020
MD, USA
That look is not for me. I much prefer the black (which is also black inside where I can still see it) and it also matches the frame. My black Ebay swingarm was in perfect condition for $110 shipped and cost little extra to have installed since they were in there anyway.
And we're done! Unexpectedly easy job. But I've got no parts left over (except a silver swing arm) so I must be OK :)
So without further messing about...
Before pics:
1st Step, get it on the Abba stand using the adaptors (note the swing arm pivot is free to be worked on):
Remove mudguard:
Remove rear wheel (rear caliper is suspended on some rope):
Support swing arm before removing shock bolt to prevent exhaust damage!:
Undo swing arm pivot nut (27mm socket) - handy tool on the left side to prevent bolt from spinning (22mm socket):
Swing arm drops out easily - tip: rotate left side down/right side up so it can clear the rear brake master cylinder assembly!
New swing arm and pivot bolt in and doing up shock bolt (t-shirt protecting exhaust form scratches).
Note the bolt needs a 8mm hex driver and a long bar to reach in (I used a T-bar to prevent it spinning)
Replace wheel & torque up. Mudguard to go on last after cleaning.
Done!
