All 650's Shift Support
JRinKtown
Jun 30, 2019
I've had one on my 650F for quite a while now. Not a big difference; just a bit more precise. And hey it looks good, lol.
mcphatty
Jul 5, 2020
One thing that I don't think many people have mentioned (perhaps I'm wrong), is that the device may extend the life of your shift seals. My other bike is a '98 Goldwing and its suffering from some really sloppy shifts. I was looking into a shift support for that as the shifter arm seems to have quite a bit of excessive play- the arm itself can move a few millimeters in any given direction with no rotation of the arm. Turns out it's a pretty common issue and the shift support is mainly added to keep the seals from failing and get the added benefit of cleaner shifts.
I'd assume that a similar benefit would be seen here. Of course we're primarly after cleaner shifts on a sport bike, but if it extends the life of parts too, that's a bonus!
Brian C.
Nov 26, 2021
Northwich
Interesting Vid, but I have been confused for a while about the "False Neutral" thing that is mentioned? I am a new rider and possibly heavy footed with my shifts, but other than occasions where I have shifted into Neutral from 1st Gear when going for 2nd (Which I think is accidentally changing to Neutral and not a "false" Neutral, that's where Neutral is?) I have never had a False Neutral on my Bike?
Is this an issue others have found where it goes into a Neutral between higher gears?
Atucker
Aug 18, 2020
I used to get "--" occasionally where it wasn't in gear and the bike had no clue what to display. I swear by the shaft support and a properly tensioned chain!
Bill_650R
Oct 25, 2021
Agree on the combination, huge difference. I would also add the importance of a properly and regularly greased shift support
RossDan
Jun 23, 2022
Zero change on my CBR650F 2014, near $100CA in the trash can
I don't think it added much. Looks cool though.
Most people saying it makes a big difference are on newer 650r machines... So maybe the old gearboxes are a bit more solid and don't get the benefits as much?
Since the quickshifter went on its good to know the extra support is there though.
FogDucker
Apr 3, 2019
Canada
Bought this to test:
C$ 16.40 54% Off | For Honda CBR650R CB650R CB 650r CBR 650r 2019 2020 2021 2022 Shifting Gear Stabilizer CNC high quality accessories
Ian Warren
Mar 12, 2022
The Quickshifter doesn’t change the geometry of the mechanism and doesn’t change the loads or directions of loss on the shift rod so I don’t see why that would require extra support?
Actually a qs does put a bit more pressure on as you haven't killed the drive with the clutch.
The dip in throttle is what let's the gear engage. You can feel the extra pressure on the gear lever when compared to a clutched change.
Ian Warren
Mar 12, 2022
Can’t say I feel any extra pressure is required to Quickshift as long as you have throttle open and are accelerating when you shift!
Definitely more pressure if you try at neutral throttle however but that not how it’s meant to work!
You may be right but I can’t say I really notice any difference except the almost seamless power on upshifts.
Did fit it within a couple of weeks of getting the bike so don’t really up shift using the clutch for comparison but downshift with clutch (obviously) feel much the same.
