Removing LAMS on 2017 CBR650F ABS
Splint
19
2
#21
I think I should have went with the ECU reflash cause I'm not that happy with the current map thats in the Power Commander v. My dealer talked me into the PCV and said he could dyno tune it for me but has back tracked since it turned up saying the map supplied would be spot on. Anyway I need to tech up a bit and throw my laptop at and play around abit. Pls send maps people. DNA filter, IXIl full exhaust 3M I think. Thanks.
Mod
1,422
770
#22
A Power Commander can only change so much of the signal it’s getting from the ECU that I don’t see it being a replacement for a proper spec ECU. So someone with a PCV map from an unrestricted bike won’t help you and your poor running.
I think your dealer over promised and under delivered. And you need a correct ECU to make everything work right.
Splint
19
2
#23
That's true about the dealer. There isn't a tune on the PC website that will come anywhere close for an Australian LAMS bike. As most people from Oz say you need a custom map to fully derestrict. This is 100% TRUE. I've done a ton of research and have spoke to 4 different bike tuning shops and today I got a flat out balls to the wall map installed. 265k top speed and it gets there pretty damn quickly. I'd love to give a BIG SHOUT OUT to Fred at PRO CYCLE DYNO Slacks ck Brisbane. Be aware you need to get an o2 sensor delete as they don't come with the pcv anymore. I'm Sooo happy as I can now keep up with my mates on litre bikes and a few on Bussers... Till we hit 220 k then they're gone. FYI
Splint
19
2
#24
30
18
#26
Thank you so much for the information about Dynobike S Splint
I’m so happy to know I don’t have to sell my bike for a full powered one!
gunmetalgrey
6
8
Thread starter #27
Sorry, I haven't replied to a couple questions on this thread.. so after I got my bike back, the performance is pretty much the same until it hits 3,000 revs and then it absolutely howls... gone from 47hp to 80 but the torque is ridiculously improved. Sorry, the mechanic created a custom map on the power commander and refused to share it. I definitely did make a point of asking. If you are in SA, the name is Neville Lush Racing. He is a proper tuning expert.
30
18
#28
Thanks gunmetalgrey gunmetalgrey
I got quoted $950 including a custom tune to make sure it's running 100%.
Now I can't wait to unleash the power of this beast!
User2
132
105
#29
It is great to hear about the thrill of unlocking a big power increase.
I like that your bike is no longer restrained. It was made to run.
Congrats!
30
18
#30
Absolutely mate!
Big thanks to S Sudesh who recommended a place that do it for $850 and the process is fully reversible when it’s time to sell :)
30
18
#31
Guys, how important is a full exhaust system? It is necessary or just beneficial?
Platinum Motorcycles want my bike for a week so I'm going through Dynobike who will do it on the same day.
Mod
1,422
770
#32
There is no difference between a LAMS stock exhaust and a full power one. So I’d say it’s definitly not a necessity in the conversion.
Steveh
3
0
#33
I have just picked up my 2018 Cbr650f bike( south Australian ) and have searched the forum for derestrict lams ecu tune.
Can you let me know how much it cost ,how much of a difference it has made and can it be reversed back if need to sell as lams approved bike. Did you keep your stock exhaust.?
I see you got it done at Neville,s does he have a workshop in Adelaide or only in Victa
Need for speed ! Urgent request
30
18
#34
I was told it can be reverse for the same cost ($950 in my case).
Also seems an exhaust is hardly beneficial for this type of bike unless you want to be heard.
No way can I justify $1.5k just for that.
No slip on option available unless you cut the pipe which I have no intention of doing.
Apart from a flash and tune, I’m told a few modifications are also required.
Steveh
3
0
#35
How much difference has removing the restriction improved the bikes performance. I I read unrestricted time 0-100 of 4.8 secs , which is not really impressive I get that out of a cbr 500r, but I suppose the lams rating is the same for both bikes.
Just want to make sure removing the lams restriction is worth it in the bikes performance.
Steveh
3
0
#37
3.5 secs more like it
What has been your experience now you have derestricted the bike, is it equivalent to an Cbr650f f unrestricted bike from factory?
where is the power band ,does it kick in a lot harder
What hp and torque did you achieve on the Dyno / remap. Top speed??
Mechanic in south Australia charges $1050 for power commander v ,machining the air restrictions ,and custom tune says it take about 4-5 hours from start to finish and indicated it went form 37 hp (wheels ) to 79 hp .
I’m just want to be sure that the power increase is significant before committing .
Thanks
