Hi folks,
I am following the user manual to adjust the engagment of the brake light when activating the rear brake as I feel its way out of spec.
Is there any special technique to doing this? I am rotating the bolt in the required direction but it is not making a difference. As it is hidden behind the rear set I cant tell if I am twising some cables so im a bit wary!
How do you guys go about this? do you remove the rearset for full access/visual inspection?
Thanks!
Thanks!
