CBR650F PCV or Reflash
Bislamatic
Sep 18, 2019
Got mine done from pro cycle dyno in Brisbane
Dynojet PCV
Dyno tuned custom map
All unrestricted
Bike cracks now
If you've got the extra coin go with the PCV. It only ends up being couple hundred more then the reflashed ecu way
gjk
Oct 14, 2017
Australia
I went to them as well, I've got the same setup as you:
Pcv
Filter
Akra exhaust.
When I got mine done they weren't offering an ecu flash as they used the Woolwich software which was not compatible with our bikes. Hence why I was asking if anyone in Qld was offering a flash now...
What go did you end up making?
