- May 30, 2014
Drill the screws out. Or just keep everything in place and cap off where the hoses attach to the engine.
Do you know if its a 24ohm resister for a fact please mate ? Ive tried to search for it but I can't find any info .A 24 ohm resistor should do it. As Mike said, 14 to 16 models don't care about the PAIR being there or not.
Will be removing pipeworks, no need for it, so will be looking for the resistor, pretty sure it was mentioned earlier what kind i need.
will take the chance and order the block off plates
It's sounds much nicer with them blanked off - but only do that if you have removed the stock exhaust and replaced with one that does NOT have a catalytic converter in it.
Block off plates from smart moto - Greece, arriving in a few days.
Will be getting the akra later on, maybe not until next season.
Is it a no go to install the block off platws with stock exhaust on my cb650r 2019 ?? If so in will just wait until i swap exhaust... Im just eager to do some modding
Will be having JIS screw drivers ready.Get a set of JIS Screw drivers. Do NOT strip the air box intake funnels screws!
