Thanks very much........any top tips on freeing up the OEM grips off the bars? I don’t really want to just cut them off.I filed down mine with a dremel. The Oxford grips come with some CA glue to ensure they don't twist on the tube. Mine hasn't twisted at all. You don't have to file it down completely smooth, but I don't think you can get the oxford grips on without any filing.
I cut mine off with a razor knife. It was a pretty simple process. If you don't want to cut them, try compressed air. Use a nozzle you can shove between the grip and throttle tube and give it a good shot of air. The grips kinda fit into those bumps on the throttle tube, so I don't know if the air will help, but it can't hurt.Thanks very much........any top tips on freeing up the OEM grips off the bars? I don’t really want to just cut them off.
