- Dec 20, 2018
So I went for aboit 50 miles this morning. It was a quick blast out and went up towards to high revs for a bit. When I got home I realised there were flecks of oil on my rear tyre. I looked under the bike and there was a film of oil around the oil filter, swing arm and on the aftermarket exhaust.
Checked oil levels and its good. No warning lights on dash. Bike has stood still for 7+ hours and not a drop has fallen on the drive.
Not sure where the oil has come from however someone has mentioned vacuum pipe may have come loose. Or it could be an over tightened chain (just had sprockets and chains replaced.) and a seal behind the from sprocket may have gone.
Where do I start looking? Do I lift the tank and check for loose vacuum/breather pipes??
