Lights on before new mot
Jun 4, 2023
Hi guys, bike Been laid up but serviced and chain renewed, just got back from working offshore so going to take for a MOT! Seen these lights after a brief start up and small ride!
The manual says it's 'abs brakes' and 'torque control'...manual says they will go off after a certain speed so plan is to book MOT and take for a good spin en route!
Nothing to be alarmed about? Bike seems to be running as usual
Cheers...Aidan
Brian C.
Nov 26, 2021
Northwich
The lights are Traction control and ABS Light, both should go off when you ride it, The ABS one will sometimes stay lit if you have run the bike with the rear wheel off the ground. The traction control can be turned off with the switch on the Left Handlebar. Nothing to worry about unless they are both still on after a few rides
Bran
Aug 31, 2022
uk
Brian, I guess you lubed the chain with the engine running! I was advised wheelies can cause the ABS light too.
