- May 4, 2021
- 2010
I’m asking if anyone has bought the integrated tail light off Amazon or eBay for the CBR650R 2020 model? If so was replacing the relay necessary since it’s already equipped with the led lights??
If the leds are round they are not bright and cheap (very old Technology). If they are flat they are SMD which are brighter. You want to be seen from the rear,I’m asking if anyone has bought the integrated tail light off Amazon or eBay for the CBR650R 2020 model? If so was replacing the relay necessary since it’s already equipped with the led lights??
I bought an amazon one and have been using it for 8 months with no problems.I’m asking if anyone has bought the integrated tail light off Amazon or eBay for the CBR650R 2020 model? If so was replacing the relay necessary since it’s already equipped with the led lights??
I would definitely like to buy one pleaseIf you interested in those taillights, I would definitely get my tucked mount. I make these and have worked really well.
How much?If you interested in those taillights, I would definitely get my tucked mount. I make these and have worked really well.
Amazon product
You will need a flasher relay, otherwise the turn signal hyper flash. I would buy the one from TST and some of their wire adapters just because its easier than splicing.
I have never messed around with relays much but I I plan to add additional flasher lights in the front and rear to run along side existing flashers, can this be done or do I need a special relay?I have a 2020 bought all leds from tst and a flasher relay however on the 2020 it's a 3 pin flasher relay and tst has either a 2 or a 4 pin. So I can only have one set of leds rear and stock front to work properly
Hey what’s up, this was a while ago so you may have realized already. But in case you didn’t, yes the oem is a 3 pin relay, but the 2 pin gen 2 from TST works with oem lights and also aftermarket front and rear setup. They explain in the install video that the 3rd pin is a ground and that they designed theirs to work without a 3rd pin.I have a 2020 bought all leds from tst and a flasher relay however on the 2020 it's a 3 pin flasher relay and tst has either a 2 or a 4 pin. So I can only have one set of leds rear and stock front to work properly
